Accessories Power Key Position
ie: It's considered safe re: the engine ignition system and such?
Radio shuts off after a few minutes unless key is in "run" position, powering a laptop via the 12v ports, the 12v ports don't work unless the key is in the "run" position.
Sitting there for 45mins with the key in "run" but with the engine off - just want to know it's safe - i had a car with electronic ignition and it was bad idea to have the key in the "engine run" position for long time without the engine actually running.
The GLK does not have a dedicated "accesories" position. It's either off - but with the key in (but that doesn't power the 12v ports), or on, and the only other position is "start".
If the brake is being held in, then the first press is straight to "Run".
