Tire PSI
Old Nov 8, 2011 | 11:03 AM
MBNA109's Avatar
2015 VW GTI.S4; 2016 Audi Q3 Prestige
Originally Posted by venchka
Does this help at all? From an interactive online MB GLK owner's manual. They mention the filler flap information as the last word.
Oh - I've been fine with that from day 2 - LOL!
I am continually amazed that it there is such discrepancy within the supply/manufacturer to customer chain.
Old Dec 5, 2011 | 04:08 PM
go1ndr's Avatar
2012 GLK 350--AMG Package 20" Chromed Wheels, Loaded
AMG Air Pressure
I just picked up my fully loaded 2012 GLK-350 AMC package. I have the new 20-in wheels and wanted them chromed (looks awesome). The dealership had a new set of them chromed there and swithed them out--same wheel, just Chromed. My question is: since they are the 20-in wheel and tire and I don't believe they are listed on the door panel or fuel cover--and since I live in So California where the weather doesn't change much year round, does anyone know the exact recommended pressure for these 20-inch AMG wheels and tires? Thank you very much for any info you can provide--it seem some say 35 for all tires and some say different info. I'm just wondering what all of you out there are running yours at.
Lastly, can these tires be rotated? I've never been able to rotate any of my previous 5 E-Classes or my wife's C-classes.
Thx!
Old Dec 5, 2011 | 04:17 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
235/45-20 tires? If so, 33 front & rear light load. 35-39 front/rear max. load. Was your GLK built with 20" wheels? Chrome won't change the tire pressure.
Your standard 20" tires are either the Pirelli or the Dunlop at the bottom of this page.
http://www.tirerack.com/tires/TireSe...ting=S&tab=All
Wayne
ps: Look at the chart on the door pillar. The tire size listed is the size the car was built with. Same size tires can be swapped front to rear.
Old Dec 5, 2011 | 04:25 PM
MBNA109's Avatar
The door pillars & fuel filler provide conflicting info but the consensus is use the normal load recommendation on the fuel filler flap & add a 1-2 lbs for convenience. So 33-35 is good all the way around. Since the air in the tires can expand by 4lbs when driven, you will feel it the higher you increase the lbs.
Thx!
Yes. rotate them every 5-7.5k miles should be fine. The tires aren't staggered.
Old Dec 5, 2011 | 04:29 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Wayne
We have the Dunlops. See the price difference???? The Pirellis are almost 33% less.... ????
For summer rubber, I may get these placed on the car. These PZero's are not USA/Canada OEM models, but are now available in our 20" size.
Old Dec 5, 2011 | 04:35 PM
go1ndr's Avatar
Thanks guys! My bad! I actually just walked out and looked at the door panel and to my surprise, it actually has the psi pressure for the 20" wheels. 35 front/39 rear! and you are correct VENCHKA, they are Pirelli 235/45 R20's. Thanks everyone!
Old Dec 5, 2011 | 04:36 PM
  #32
venchka's Avatar
OEM tires:
http://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=Scorpion+Zero +Asimmetrico&partnum=345HR0SCOR0AXL&vehicleSearch= true&fromCompare1=yes&autoMake=Mercedes-Benz&autoYear=2011&autoModel=GLK350&autoModClar= $193/each.
http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=Grandtrek+Tour ing+A%2FS&partnum=345HR0GTTASXL&vehicleSearch=true &fromCompare1=yes&autoMake=Mercedes-Benz&autoYear=2011&autoModel=GLK350&autoModClar= $293/each.
Go figure.
Alternate summer only tires/not shipped from factory:
http://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=PZero&partnum =345WR0P0XL&vehicleSearch=true&fromCompare1=yes&au toMake=Mercedes-Benz&autoYear=2011&autoModel=GLK350&autoModClar= $283/each.
It's your money.
Wayne
Old Dec 5, 2011 | 04:38 PM
  #33
venchka's Avatar
Cool
Good. You got the better of the available tires. Now go to the fuel filler door and read the pressures to use in the real world. Two sets of numbers. Low for light load. High for maximum load.
Wayne
Old Dec 5, 2011 | 04:50 PM
  #34
go1ndr's Avatar
Will Do! Thanks again!
Old Dec 5, 2011 | 04:52 PM
  #35
MBNA109's Avatar
Warning: That's max load & you might not like the stiff ride.
Remember what I said, air will expand 4 lbs.
You can see this on your COMAND dash monitor after only a couple miles of driving.
Go back to your fuel filler flap & use the in between light & heavy load (33-35) & you should be fine esp. since SoCal doesn't get much cold air to worry about pressure loss.
Old Dec 5, 2011 | 04:56 PM
  #36
go1ndr's Avatar
THX
Old Dec 5, 2011 | 07:50 PM
  #37
go1ndr's Avatar
The new pressure gauges on the dash look cool but don't seem to be too accurate. I went by my local tire store and the tech put in 39lbs in the rears and 35lbs in the front. Done on a digital air machine that is 100% accurate. I drove out and they showed 35F/38R--15 mins later they showed 34/35F--37/38 R! 10 mins later they showed 34/35F--37/37R. So I'm not going to look at it anymore--LOL! I saved the 35F/38R as the marker on the system. Still amazed that with all the technology out there, this simple gauge doesn't work. Still thanks for all the much needed advice today! Best!
Old Dec 5, 2011 | 08:09 PM
  #38
go1ndr's Avatar
PS: don't notice any difference in ride either--on freeway or local streets.
Old Dec 6, 2011 | 09:22 AM
  #39
venchka's Avatar
Cool
... I went by my local tire store and the tech put in 39lbs in the rears and 35lbs in the front.
Best!
Say what????????????????????
Are you in a carpool with several NFL linemen?
Wayne
Old Dec 6, 2011 | 05:05 PM
  #40
go1ndr's Avatar
Could be, the Cowboys train across the street from my home!
the gauge shows 33/34 in front tires and 36/35 in back and keeps changing so my guess is the gauge in the car isn't too reliable.
