Bigger tires?
The 255-40 has a diameter of 28.0 inches
This is a difference of 1.1%
If you use the 255-40 when your speedometer reads 60MPH, you will actually be traveling 60.7MPH.
While I was at the dealer and since my friend is on the higher ups, we took out a plane jane 350 with 20,s and went on what we call the "Turnpike" in S Florida.. we were tooling around at 117 mph and there was no wind noise but the car did have what felt like a slight sway to it,also it had more power to run. I am use to (Infinity's)..anyhow we proceeded to get off of an exit that was marked exit speed 35mph and we were doing 80mph and the car was like glue to the road. So this was my fooling around test with a dealers car.. Last I was advised to change oil at least every 5000 miles even though it says 10000, and not to worry about breakiung the GLK in.."Drive like who you are" is what I was told.
The tires are the weakest link. Riiiiiiiiiight...
But I hate it. The ride is too firm for Quebec roads and you can feel everything, especially with the worn down (+220 000km) original suspension. I just bought new wheels and tires, and I am switching back to higer profile tires.
Also, I noticed a 10-15% increase in fuel consumption with the 255 compared to my narrower winter tires. So what's the point ?
