Getting throttle to "relearn" our driving style
GLK 350, Audi TT
Hello.
We just purchased a a year old GLK and love it.
This is the first time that I HAD to read a vehicle's manual in order to take advantage of all of the features - I'm still learning the correct procedure for having Navigation respond to a POI request.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
We'd like to have the throttle readapt or relearn our driving style. I've seen a post about this in the w204 forum, but I'm not sure if I should use the same procedure for our GLK.
I'm assuming that the C and S settings adjust shift points using some standard "C" and "S" formula based off of our "normal" driving style. Right?
Thanks.
Thanks.
Hello.
Thanks.
Thanks.
and yes, the car does learn your driving on both settings - c and s - based on predetermined criteria (s = 1st gear start c = 2nd gear start, c shifts a 3500 rpm and sport around 5k)
furthermore it won't kickdown as much in c as compared to s...will hold the gears longer before moving down 1 gear - sport kicks you down two
2010 Barolo Red-Almond/Black GLK 350, 2008 Cadillac Gold Mist LUX III DTS
No need for everybody to scurry over to the W204 board and do searches on How to Reset.
1- Turn Ignition to ON (Just short of START.)
2- Fully depress gas pedal for 5 seconds.
3- Turn Ignition OFF
4- Release Gas Pedal
5- Wait at least two minutes before starting and driving car.....
No one seems to know how long a learning cycle is etc....
If you have babied this car when you broke it in.........how long before it adapts to "normal" driving......if you start giving it the gas....how long before it adapts to "aggressive" driving........
Seems to me that even if it learns very fast, and you are not in some repetitive mode, like track racing......the learning will always be behind the actual requirement?
GLK 350, Audi TT
Thanks for the throttle relearning tips
RR: As you say, I don't expect anything dramatic to happen.
But just on principle, seems like something I must do, to make my GLK belong to me, rather than the person who owned it for a year before me.
Just a matter of car hygiene, if you know what I mean.
Normally, I'd also change the air filter right away, with the same sort of spring cleaning mentality. But given the steps required to gain access, I'll put that off for a while.
Mercedes Benz GLK-350
2004 Volvo XC70; 2012 GLK 350 4matic
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
The throttle may not adapt per se, but the transmission does. Or so I am led to believe.
Wayne
