Help, is this an issue about brake
Old May 13, 2010 | 10:30 PM
shadowred's Avatar
GLK 350
I just got my GLK two weeks ago. My first MB, love it. But yesterday after I stopped for the red light, I released the brake pedal and then tried to step on it again, I wasn't able to press the brake at all, the pedal was locked(at the up position). The car didn't move, until I hit the gas after the light turned green. Then brake worked normally again.
Is this an issue, or by design? I am able to reproduce this situation later on again. Do I need a trip to the dealer? Thanks.
Old May 14, 2010 | 10:48 AM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Sounds odd... do you normally *pump* your brakes? This does drain the vacuum from the brake booster and can give you the feeling you describe... otherwise a trip to your dealer may be in order.
Old May 16, 2010 | 08:15 AM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
Although your description doesn't exactly match how the "Brake Assist System (BAS)" works/behaves, the BAS kicks in if you apply the brakes very quickly. Note the "GLK Operators manual". It depends on how you entered the red light and applied the brakes, and how quickly you pressed the brake pedal when you reproduced the situation.
Another driving system of the GLK is the "Hill-start assist system". Again, from the manual: "On uphill grades, the hill-start assist system maintains the pressure in the brake system for approximately 1 second after you have
released the brake pedal. Therefore, you can start off smoothly without the vehicle moving immediately after releasing the brake pedal."
As well does this one not match your described situation exactly, however might design like this be a little confusing, as you got the GLK only a short while ago, rather the being an issue.
Old May 17, 2010 | 07:38 PM
shadowred's Avatar
GLK 350
Thanks for the reply. I don't think the way I hit on the brake was hard or sudden. Since it only happens in uphill situation, yes it might related to BAS. But I will bring it in to the dealer to confirm.
Old May 18, 2010 | 07:53 AM
GLKKa2H's Avatar
Thanks for the feedback
Kindly give us a note when the dealer have spoken, as there may be a lesson learned to more of us
Old May 19, 2010 | 10:15 AM
shadowred's Avatar
GLK 350
It is confirmed that yes it is the BAS. Not an issue.
Old May 19, 2010 | 10:30 AM
MBRedux's Avatar
Old May 19, 2010 | 01:58 PM
GLKKa2H's Avatar
Thanks. May you be happy with your GLK
