iPhone 4 cradle with power charger
If you can find it, I am using a TuneFlex Aux with SmartClick from Griffin - http://www.griffintechnology.com/pro...ith-smartclick
Found it at Best Buy in the discontinued section. Sad, as it's perfect. Plugs into power adapter and there's a 3.5 mm cable from the base of the unit that I feed into the aux input. It charges through the base and the audio comes out of the dock, so it's much better quality.
I am not using any of the adapters - simply set it onto the connector - holds it firmly enough.
![](http://www.n8webs.org/misc/iphone1.jpg)
![](http://www.n8webs.org/misc/iphone2.jpg)
