low fuel warning indicator
2011 glk 350
hi all..
does anyone have this problem.. i've been noticing that the low fuel warning light comes on when there's still 2 notches before E..
kinda odd that it gives the warning so soon..
thanks..
thanks..
2010 Mercedes-Benz GLK
Same here..... I guess earlier rather than later is better. However, I don't like that while the low fuel light is on, you cannot use your display to watch your consumption or distance to empty. That part sucks!
2010 GLK 220CDI 4M BlueEFFICIENCY
Are you saying that if you clear the low fuel warning with the OK button you still can not see some items on the speedo display? I'll have to check that next time the warning is displayed.
2011 glk 350
thanks to all who replied.. so it isn't me who thinks it's a problem with 2 notches to go before filling up..
cheers
Keep in mind that the 4 obvious marking on the fuel gauge are the official markings the others around the dial match those of other gauges and might represent 1/16th of a full tank. At 19.5 Gal US do the math and you will see that 2.4 Gal is close the 2.1 Gal claim to the level that MB says thats when the indicator should light up. Close enough!
S600,GLK350,528i,G35,X3,C320,330i
Would you like warning light come on when tank is empty? I think on GLK with its tiny tank it's a good warning level. On my older cars I could go another 70-100 miles with light on.
