how do you remove 2009 glk radio ?
In less than 2 hours 75 people looked at your post, not one responded. Although GLK's came out in 2009 they were labeled as 2010's. If you are looking for an answer you need to explain yourself a little better. We will try to help.
If you really want your radio removed I know a few places you can park and the helpful locals will no doubt oblige you before you can blink an eye!
They may not stop at the radio tho...
Mercedes Benz S 550
Before performing any task involving the electrical system of the Mercedes, you need to disconnect the negative battery cable from the battery. The negative battery cable is black and connects the battery to the frame of the Mercedes. Use a 10 millimeter wrench to loosen the grounding cable's clamp. Remove the clamp from the negative lead post. Rest the clamp away from the battery until your work is completed.
Incridez does not seem to be too concerned. Incridez never responded to the initial request to better clarify what they wanted.
If the old owner took your GPS antenna (what ever that might be) then you should talk to the old owner. I assume you bought your GLK privately.
