How to remove hatch panel to install backup camera?
GLK350
Hi, does anyone know how to remove the hatch panel on the GLK to install the backup camera? A procedure or pictures would be helpful.
1000000 Thanks!
1000000 Thanks!
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
No one has done it. We purchased the BUC with the car. Can't be that hard. Open the rear panel from the inside and unbolt it. Running the line and rigging it to your existing system will be fun.
Just buy an aftermarket unit.
![](http://i01.i.aliimg.com/photo/v1/358200791/Waterproof_Color_Backup_camera_for_Mercedes_VIANO.jpg)
Don't get so snooty...
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
GLK350
I used to work on my w203 and w204 C CLASS inside out, but this one seems very difficult; the rear panel is very tight, no visible clips, if not remove properly, there will be lots of rattle noise.
Why would you even want to try?
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
The plastic panel is held in by *grip-clips* similar to the pix below. Can't find a pix of the MB clip itself, sorry. Little plastic tabs on the panel are pushed into these clips. The grip holds it on. But to be safe, I would consult your dealership's body shop. And yes, it will probably make noise unless the clips are replaced with new ones after you're done installing your camera.
![](http://fasports.com/test/clip.jpg)
Here are some shots of what you're in for and tools you'll need. Like always, proceed at your own risk!! Good luck!
![](http://www.glm811.com/imprezadoortrim/6cliptool.jpg)
![](http://ecx.images-amazon.com/images/I/41xuvaMYOkL._SL500_AA280_.jpg)
or even better...
or even better...
![](http://www.tooled-up.com/Artwork/ProdZoom/SEART006.jpg)
Here is the link to a China Auto shop on changing out the LCD COM + Radio + backup camera.
http://club.autohome.com.cn/bbs/thre...9996981-1.html
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Notice the trim tools they're using are plastic like these only yellow... less damage.
![](http://a248.e.akamai.net/pix.crutchfield.com/products/2010/27/126/p126CR6NGL-f.jpeg)
