lift gate question
Old Sep 19, 2011 | 07:34 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
lift gate question
I just noticed that my glk power liftgate will open and not close using the driver's door liftgate button. It only happens when the car is not turned on. Is this normal?
Old Sep 20, 2011 | 12:07 AM
icool007's Avatar
2011 GLK350 4MATIC, 2013 GLK350 4MATIC
you need to press down to close... did you do that... pull up to open and press/push down to close on that button...
Old Sep 20, 2011 | 03:06 AM
yes i did! it will only not close when the engine is not running. try it on your glk and see if it is the same.
Old Sep 20, 2011 | 10:06 AM
bop11's Avatar
350 GLK, C280
Mine opens andcloses with the key turned on
Lift up on the switch to open
Push down on the switch to close
Pretty clever these Germans!
Old Sep 20, 2011 | 11:16 AM
Beal's Avatar
2010 GLK
This is how my 2010 works also. Opens anytime from drivers door, only closes from drivers door with ignition active.
Kind of annoying and probably some liability concern?
Old Sep 21, 2011 | 02:54 PM
I was told it is like that and they can't do anythng about it (I do believe they can just a programming thing) but during the testing the car's gate started acting up like not opening fully or smoothly so i left it to the dealer. Nice as they let me drive a ML loaner which I'm liking and reminds me of my previous murano because of the size.
I do hope the liftgate will not be a headache and gets fixed and won't do the same thing after the warranty.
Old Sep 23, 2011 | 01:14 AM
icool007's Avatar
Yeah, I just tried mine today. It acts the same way as yours.... so dunno what's going on..
Old Sep 24, 2011 | 08:21 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
works same here
It never bother me as I never use inside button. I ether use the key or button on the liftgate itself.
Old Sep 24, 2011 | 08:26 AM
NYCGLK's Avatar
Not openning fully might have to do with you activating height limit (i.e. you can set the tailgate to open to certain level only if you have low ceiling in the garage).
There were issues with tailgates on 2010 models, where tailgate would not open. It would open and inch and then close right back. There was adjustment for that and my lift gate has been working like a charm past two years.
Old Sep 28, 2011 | 03:49 PM
they ended up replacing the motor and control module for the liftgate. they also reprogrammed it to the point that when it reaches its last 3 to 4 inches it will slowly continue before it will stop not like before it will just stop abruptly-the snaping noise also dissapeared after this adjustment. Also when it closes it does the same thing last 3 to 4 inches it will slowly close. I was told that way the motor's gears won't get stressed when it it reach its end.
Old Sep 29, 2011 | 10:09 AM
Beal's Avatar
2010 GLK
Glad to hear it's fixed
Old Sep 29, 2011 | 10:51 AM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Cool
Note to Self:
Self, make sure the liftgate is adjusted to this specification before writing the final check.
Thanks for the detailed explanation.
