Techniques for rotating tires at home (without lift)
2010 GLK 350
Our GLK is 1 1/2 years old with 8000 miles (grocery getter, wife doesn't work). The courtesy dealer rotation was done at 5,000 miles, but as I get closer to the next rotation I plan on doing it at home.
For those of you rotating your tires at home, I'm trying to determine the best/safest technique used to handle this task (as there are only 4 jack points, and the tires are to be rotated front to back same side).
Right now I'm thinking of using a "spare" 5th wheel, and jacking only one wheel at a time. Only problem is my "spare" is a rim only right now.
Let me know your thoughts and what's been working for you.
-Nick
-Nick
Jack Adapter
https://mbworld.org/forums/cls-coupe...k-problem.html
2010 GLK 350
Ok, so you just jack the front right which lifts the right rear and swap the two wheels, then do the same with the left side. I've got the Reverse Logic jack pad tool which fits nicely inside the saddle of my jack. Yours looks like a nice fabrication for a jack with a smaller saddle. Thanks for the info.
-Nick
-Nick
2004 Volvo XC70; 2012 GLK 350 4matic
Block the other two tires SECURELY! A friend of mine lost a neighbor recently when his car fell off of a jack or jack stands. I don't know all of the particulars except that the guy is no longer with us. Be careful! Be safe!
Wayne
Wayne
