Turn signal goes opposite direction as switch back to neutral
Old Apr 19, 2012 | 01:46 PM
yaester40's Avatar
2011 GLK350
On my 2011 GLK 350, I have been often experiencing the following problem. If I press combination switch to indicate a right (or left) turn, but do not make such turn, or only turn a little bit (e.g. lane change) and press the combination switch back to neutral position, the right (or left) turn signal goes to the opposite direction - left (or right) turn, rather than going off. I have to press combination switch to the opposite direction - right (or left), the turn signal goes to right (or left) again.... So, the turn signal is back and forth between right turn and left turn, but not off. The problem stops only after either I make a sufficient turn, or I shake steeling wheel a little bit right and left back and forth quickly for a while. I am sure anyone driving behind me would think I am crazy.
I reported the problem to my dealer at 10,000 mile service. They could not duplicate the problem.
Old Apr 19, 2012 | 02:28 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Can you feel the lever stopping at the center position? Perhaps the detent isn't stopping the lever correctly?
Wayne
Old Apr 19, 2012 | 02:54 PM
yaester40's Avatar
2011 GLK350
Yes, I have been paying attention to ensure the combination switch level back to neutral position. At the beginning, I thought the lever may not be back to neutral position, as you think. But, that was not the case. The turn signal light in the opposite direction becomes on even when the combination switch lever is back to neutral position.
Old Apr 19, 2012 | 02:58 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Are you engaging the lane change function? ie: tap to flash 3 times instead of a full signal?
Old Apr 19, 2012 | 03:08 PM
yaester40's Avatar
2011 GLK350
No, I have not tried that option. I just know that option from GLK owner manual this morning.
I have driven many other cars, but never had such uncomfortable experiences on turn signals, as I described.
