GLK Low Beam Headlight Replacement - and the dreaded spring/clip
But again, does anyone here have a link to a good replacement part?
I found this and it looks just like one that fell out of my 2010. See if you agree.
https://www.smart-stuff.parts/h7-hea...gaAjTOEALw_wcB
I would contact your local MB dealer to see if they have a way of getting just the clip spring because this is a common problem.
I will keep researching as well.
Jeff
Try calling your local parts and asking for part #0009932607 - this one fits a wide range of models, so it's not just for my 2010 GLK350...
Sorry for the false hopes. The clip that matches part # 0009932607 isn't the same clip in the video, it looks like 90% of the others generally available out there with the large sections that bend back (and not mostly flat). I sent this vid to Tyler at MB and he's going to research and see if he can get the part. Meanwhile, here's a pic of what was in my MB. It wasn't the previous clip, but a section of 14 or 15 ga electrical ground wire... Give the guy some credit for McGyvering this when I'm assuming he ran into the same problem as the rest of us, lost the clip and couldn't find just that one part without buying the entire unit.
1. Removed and threw awaythe headlight housing clip
2. Epoxied three 0.25" diameter magnets around the outermost surface of the bulb fixture on its housing-facing-side (Sorry - I forgot to take a pic of this but I'm sure you can figure out where to glue the magnets)
3. Reconnected the bulb fixture power supply
4. Inserted the bulb fixture into the headlight housing. The section of the housing which touches the fixture is made of metal which is why magnets do the job.
5. Turned the headlights on and adjusted the alignment of the new bulb fixture using my garage door
BTW - the magnets (see pic below) cost me $5 at my local Michaels store.
The left (original) was easy enough - just reach above the bulb, push the clip up about 1/2", slide the old light out, slide the new light in (tab straight down) and push the wire clip down 1/2".
The right was a little scarier since there's no way in the world that pivoting clip is going to clear the fan / housing behind the bulb. Turns out the LED "bulbs" I bought have a removeable baseplate, so it was just a matter of putting it in place (just like a regular H7 bulb) and the pushing the much larger LED bulb into the baseplate.
FWIW, this short (no narration) video I did might help:
Mercedes GLK350 Installing daytime running lamp/low beam spring/clamp
Mine GLK350 with AMG package looks different. I have search the web looking for my clip, it is nowhere to be found. Anyone shine any light on my issue?
I bought some washers with an interior diameter of 0.75" and an outer diameter of 1.25" (outside diameter was actually a bit larger and I ended up trimming it down). Then bought some neodymium magnets from buymagnets.com. I purchased a range of strengths from N42 to N55, I'd recommend the N52's (0.25" diameter X 0.125" thickness).
I went out in the garage and drilled a bunch of holes in the washers just slightly smaller than the magnets diameter and hammered them all into the washers. You're gonna want to get the magnets fairly close to the outside of the washer rim. After that I just slid them onto the backs of the lightbulbs and they stayed in place really well, which was super important for installing them as we all know you have to contort your hands all kinds of ways to get the bulbs in place. When I installed them, as soon as I got the bulbs in the correct position the magnets took over and everything was good to go. It was easy to rotate them to get the light beam dialed in and you can take them out if you have to fairly easy as well.
This worked for me and I'm super happy with it. Been driving with perfect headlights for a couple months now and it's a huge relief. Anyways I thought you guys might be interested. Here's some pics, cheers.
Nice job on the magnet solution. After 12 years ownership on my 2011 and ~ 4 low beam changes later, the process got easier each time. When I look at Today’s landscape in comparison; having a rwd bias, port injected, timing chain ( others have caught on to chains), naturally aspirated v6 with a decent displacement … are all such luxuries in their own right that finding a replacement for the GLK can’t be easily done and a finicky headlight bulb replacement is a minor inconvenience I can live with.
I've also really enjoyed making it my own by doing a bunch of DIY upgrades:
- The car is like an arctic white color and the rims came black with red calipers so I've been kind of following that motif, flat black with red accents
- I did the door trim, bumper trim, and the bumper skid plate matte black.
- Outer door pillars between the front and rear doors I made flat black
- Window weather stripping trim at the bottoms of the windows flat black (basically all exterior trim or accents I either painted or plasti-dipped flat black)
- Trunk emblems and hood badge are flat black with red accents
- I got smokey lensed LED turn signals for the rear view mirrors and painted them flat black
- Grill is black with black illuminated Mercedes emblem
- Aluminum racing pedals
- Windows are all super dark tinted
- Xenon headlights
- Updated the stereo system:
- JL Audio C5 6.5" front door woofers
- Hertz HT 1" tweeters
- JL Audio C2 6.5" coaxials for the back door speakers
- Audison AP8.9 Bit DSP amplifier (digital signal)
- Audison AP1D subwoofer amplifier
- JL Audio 12TW3-D4 thin mount subwoofer
- Added Apple wireless CarPlay//screen mirroring//extra USB port
- Added a backup camera
- Removed the cigarette lighter and replaced it with a 2-port USB-C fast charging and USB-A charging plugin
- Bought some new door lock and AC buttons bc they were kind of worn off
- Going to powder coat the exhaust tips matte black this week
Anyways I've really found this forum to be a huge cache of helpful info as I continue making all these upgrades, so I thought I'd contribute.
I actually just found a website where you can purchased neodymium washer magnets that are axially magnetized, so I ordered a few. They should just slide onto the back of the headlight bulbs and since the entire washer is a magnet it should work even better. I ordered these two kinds (both are N42 strength bc I figured if the whole washer is magnetized it shouldn't have to be quite as strong):
LINKS TO MAGNETS:
- Link to RX8C2
- Link to RX4C2
If anyone is interested I'll grab some pics of my GLK and post them up here. Cheers.
