Hitch and max weight
Old Jun 18, 2012 | 10:20 PM
elitehak's Avatar
glk350
Hello everyone,
have a glk 350 2012; with a hitch 1.25 by 1.25 receiver, max pull weight 3500 pounds...i purchased a trailer (19 feet, ultra lite prowler lynx dry weight 3150) will this be enough to pull it considering the receiver seems small, and the extra weight we will add: propane, food, etc.? will the glk survive
or do i need to change the receiver for a 2inch by 2 inch?
Eli
Old Jun 18, 2012 | 11:39 PM
3.5L's Avatar
2024 GLC300, 2014 BMW M235i
The GLK is rated to tow 3500 lbs. when equipped with the factory tow package. Check the owners manual, but I think it states that the tongue weight should be somewhere between 15% and 18% of the trailer weight. Keep track of what you load into your trailer and do not exceed a maximum gross weight of 3500 lbs.
BTW. what are your intentions regarding trailer brakes?
3.5L
Old Jun 19, 2012 | 10:09 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Max. Tongue weight = 350 lbs.
Learn before you buy things.
Wayne
Old Jun 19, 2012 | 10:31 PM
3.5L's Avatar
Wayne
Uh, where did you get that figure, Wayne? On page 159 of the Operator's Manual it clearly states the the drawbar noseweight remains between 8% and 15% of the permissible gross trailer weight. On the same page, the permissible gross trailer weight is stated to be 3500 lbs. A little math concludes that the permissible tongue weight for the GLK is 280 to 525 lbs. for a 3500 lb. trailer.
Cheers,
3.5L
Old Jun 20, 2012 | 07:45 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Look under the hitch itself. There is a Westfalia manufacture sticker that tells you the exact specs. It is pretty low on the GLK if I recall. I am not near her's now to say what it is. That hitch is really for things like bikes, jet skies or a snowmobile, not campers.
elitehak, by time you load the camper and put everyone and the dog in the GLK, you will be overloading something.
I would say change to a bigger tow vehicle if you really want to go RV camping.
Old Jun 20, 2012 | 12:28 PM
3.5L's Avatar
Good tip, thanks dgiturbo.
I just now crawled under our GLK with a flashlight and located the sticker. The maximum allowable tongue weight is 280 lbs. Also on the sticker are specification (restrictions) for drawbar length and lift or drop.
I'm planning to tow a Palomino Tent-trailer with our GLK. The tent-trailer has an empty weight of 2275 lbs. Fully loaded, it weighs 2890 lbs. and has a tongue weight of 260 lbs. All of these figures are under the maximum figures of the car and the hitch itself. In addition, the tent-trailer is equipped with electric brakes, so I think this whole package will be road worthy.
3.5L
Old Jun 20, 2012 | 12:50 PM
venchka's Avatar
Thanks dgiturbo. I was going off of MBUSA numbers and Class II hitch specs. Both sources vary a lot. Why couldn't MBUSA have told me where to look? Those folks are criminally dangerously incompetant.
Wayne
Old Jun 20, 2012 | 01:26 PM
3.5L's Avatar
You're right, Wayne. There certainly is conflict between the Operator's Manual and sticker on the hitch regarding tongue weights, not to mention the lack of complete wiring at the 7-pin hitch socket.
I've had to do an unusual amount of research to satisfy myself that my car/trailer combo will be safe and not over-tax the car or hitch. Once I hit the road, I don't want to find myself worrying about anything.
These forums are great!
3.5L
Old Jun 22, 2012 | 08:57 PM
3.5L's Avatar
I picked up my Class II drawbar today. It came complete with 2" ball (installed) and pin. $29.41 out the door. I purchased the drawbar from a very reputable RV dealer/servicer in my area.
After I picked up the drawbar I walked back to the service shop and asked one of their technicians some questions about my Class II hitch. I explained the hitch restrictions (on the sticker), weight of my tent trailer, plus the tow rating of the GLK. He said I'm fine, nothing to worry about. He explained that there is a great deal of additional strength in the hitch beyond the load limits of 3500 lbs. (towed) and the 280 lbs. maximum tongue weight. This allows for a safety margin and accommodates the stresses and strains of bouncing around on less-than-perfect road surfaces, etc.
My drawbar is made from solid steel. I'm having 2.25" cut off and the pin hole re-drilled by the same RV firm to comply with the hitch specification of 6.5" maximum distance from center of pin to center of ball.
I plan to install my new Tekonsha Prodigy RF brake controller this weekend and then take a test run.
I'm not worried about this car and trailer combo anymore.
3.5L
Old Jun 22, 2012 | 09:27 PM
dgiturbo's Avatar
Just got back in town. 3.5, sounds like you should be good to go. I am actually in the process of RV shopping now, but the model I am looking at has to be pulled with the ML. (Prime Time Tracer 230FSB)
Here is a photo of the 2012 GLK Westfalia tow sticker for anyone's future reference. Note the drop restrictions etc.
By the way, the stickers fade out after a few years, and fade faster if you try to wipe dirt away so you can read it. Ask me how I know...
Just wish I had taken a picture of my ML's Flex N gate sticker when it was brand new.
Old Jun 22, 2012 | 11:10 PM
3.5L's Avatar
Just got back in town. 3.5, sounds like you should be good to go. I am actually in the process of RV shopping now, but the model I am looking at has to be puled with the ML. (Prime Time Tracer 230FSB)
Wow dgi, that's a hunk of trailer! But with your CDI (398 ft/lbs torque?), it should move just fine. Class III hitch I presume?
Happy trails,
3.5L
Old Jul 4, 2012 | 12:01 AM
Lattanzio's Avatar
E320 & GLK
Thumbs up GLK towing
I tried to find info about towing small trailer for camping, this info provided everything & more to make want my ML back. GLK is nice but after 10 years with the ML ideally miss it & I wouldn't have had the concerns I have now about what I can & can't do with the GLK, didn't even think about the brakes! thanks for great info.
