Super annoying ECO behavior
Anyone else? Seems like it should just stay powered down in Park... unless there's some sort of special "standby" for mechanical systems for ECO mode?
(this is a holdover from my days as a cop, where the first priority was to be prepared to get OUT of the car, second was to shut the engine off)
Undoing the seatbellt or opening the door causes the engine to start. I suspect there is a delay built into the "park" switch, where it gives you a few seconds to shut off the engine.
Also, if you open the door, the vehicle puts itself in park. Now I shut off the engine in drive and then press the park button, and if I miss the park button, opening the door puts it in park.
1) pull into space, come to complete stop
2) ECO kills engine
3) Put car in Park (very deliberate, since this is a push button instead of a lever and I'm not used to it)
4) Engine re-starts
5) a few seconds later turn off engine with key
6) Put in emergency brake
7) remove seatbelt
8) open door
So basically in the space of 10 seconds the engine stops, starts, stops. It's not... "aesthetically" pleasing.
The "Automatic engine switch-off" and "Automatic engine start" is a rather (too) complex story if you ask me. Have you read all four pages to see if anything matches/provides clarification for your case?
Maybe I'm releasing my seatbelt... but that doesn't seem right. I can almost certainly say as soon as I press the button for P the engine kicks back on. I'll have to test it out tonight and pay close attention, see if I can remove some of the variables. Perhaps the ECP software needs an upgrade.
Hope that works. Now i just gotta figure out HOLD. works 1 in 5 tries, lol
My impulse was to unhook the seatbelt (normal order of things for me) which would have started the engine.
I hit the off button then seatbelt then door. So the engine stayed off the while time.
And that's actual consumption from fillup to fillup, not from the computer.
Yes, you should have your foot on the brake until your vehicle finishes shifting to the selected gear, as per the manual. Any motion while putting the car into P/R/N/D can damage your transmission.
I bought a 2011 E550 because I saw what was coming in the 2012's and beyond. Car manufacturers are being forced to switch from a priority of performance and reliability to fuel economy and emissions. My E550 has no turbo, no direct injection with the complex and costly injectors, no fuel in the oil, no worries about valve problems. Just a beautiful, state of the art V8 without the complexity of the newer cars.
The table of "Problems with the engine / Possible causes/consequences and ►Solutions" in the GLK Operator's Manual, is interesting reading.
