Rims
Old Dec 6, 2012 | 09:44 AM
regina_sk's Avatar
2010 GLK 350
Rims
Hi,
Am considering to get winter tires and have found used rims online. He used to use these rims for his 08 ML and am driving 2010 GLK. He said these rims should fit in my car but it seems like specification seems a bit different but not much.
08 ML: 17X7.5, 5 x 112 bolt spacing, 45 mm offset and 65.7 backspace.
Specification I found online for my car (2010 GLK)
- Size: 7.5” x 17”
- Offset:47.5 mm offset, Hub
- Hub: 66.6mm
- Lug Pattern: 5X112 mm
Do you guys think i can buy these rims form 08 ML to use on 2010 GLK?
Thanks a lot!
Old Dec 6, 2012 | 11:55 AM
Sharaf's Avatar
GLK 2010
I would check the center hub for the ML first, if its 66.6 then you are good to go
Old Dec 7, 2012 | 05:40 PM
Mort's Avatar
Are the wheels from the ML OEM or aftermarket. If they are OEM then they should be hubcentric at 66.6mm. You do want hubcentric wheels so worth checking.
