Glk exterior door handle/actuator help
I am replacing the actuator on my drivers door. I have everything removed except the exterior door handle and actuator. The small rod that connects the actuator to the door lock is holding me up(in order to remove the actuator). This has me to believe that I need to remove the door handle/cylinder to remove the rod. I located what I believe is the t-20 torx screw that I need to loosen in order to remove the the lock cylinder/handle but it does not budge. I have searched forums, google and you tube searches but have come up empty on the GLK.
If someone has a diagram or instructions it would be greatly appreciated it.
p.s. in hindsight not worth all the hassle to diy but curiosity got the best of me...
- except CODE (Z04) Light armoring [models 212]
Component Identification
Steps 1 - 12
Steps 13 - 22
Special Tools
Repair Materials
