Can GLK250 Bluetec fit a donut spare in the well?
Read tread https://mbworld.org/forums/glk-class...n-flats-2.html
In some places, the diesel costs more than gas which eats into the savings too.
the only reason to buy the 250 is fuel savings right?
The AdBlue tank in GLK250 is ~7gal. The 2.5gal canister in the local Walmart is ~$11 and you can add it yourself.
It's a big discussion gasoline vs. diesel. I like the 369 lb-ft of torque. On the long run diesel beats gasoline.
How about this link http://news.wyotech.edu/post/2012/03...diesel-engines ?
Now, I'm wondering what the cost analysis is when taking into account the added price of run-flats. This article implies they wear out much much faster
http://www.autoguide.com/auto-news/2...-buy-them.html
Fuel savings should be lower on the list.
Maintenance will not be much more than other vehicles.
Run-flats are actually a +.
BUT, you need to love diesels to own one. If you haven't had one, make this a first one. You will not regret.
Tires: I have not been a fan of run flats in larger/heavier SUV's - like ML and GL - to me they have a noticeably harsher ride - even when fresh - on the lighter/shorter wheel base dirivng a new/new I don't get that same type of harsh feeling.
Under a "nrmal" leak - thru the tread portion - run flats are designed with very stiff sidewalls to allow you to move off-traffic even if the leak is dramatic under low/no pressure - with "standard" tires if you have a dramatic leak/blowout you will trash the tire easily as the wheel cuts the sidewall when low/no pressure - "more" runflats can be reapired and "less" "standard" tires can be repaired.
Under "slow" leak thru the tread - Road Side Service at least in my area can reapir either on site... under dramatic blow out then Road Side "should" cover a Run Flat tow to the nearest MB dealer...
On tire life - my personal estimate is Run Flats will have longer life than Run Flats on heavier ML/GL - but yes, Run Flats will not - my opinion - run 30K+ like some "2nd set" tire replacements can.
I say 2nd set replacement - since my personal suspicion based on my experience is that tire manufacturers supply OE tires for manuf with softer compound - because frankly ALL 1st manuf tire sets last like 25% less than 2nd set tire replacements same tire - go figure that !
Maintenance - Maintenance for the 250BT is the same with two exceptions - AdBlue/DEF at 10K miles - as prior noted generic/Peak-recommended is easy DIY - get one MB bottle to cut/use as a funnel - and will save you over $150. 2nd additional cost is the diesel fuel filter which for ML350BT is every 20K miles - I have not drilled down into the online Owner's Manual to check on mbusa.com owner support section to see if 250BT is the same interval yet.
Fuel Economy Savings: Are in direct realtion to fuel cost - my area disel is the same as premium for the 350 gasser - and how many miles you plan to drive. Frankly, the "guesstimate" on increased fuel economy real dollars with equal fuel cost is about 30%
Driveability: The GLK350 can do amazing things in S mode - especially when using paddle shifting correctly - that 300hp can really kick. That said, the 250BT can be amazing too, especially around town, with that torque with no paddles.
My opinion right now the 2013 GLK is severely under rated and severey under reviewed - the GLK350 well driven will kick butt - BMW "sport" X3 guys, paying more - get a 4-banger and the GLK has 300hp 350 engine. The GLK250BT kicks butt - this isn't a wanna-be VW truck engine..
Keep the beat !
Although it's too early to say for sure, diesels do tend to hold their value better than their gasoline counterparts. If that holds true for the GLK250, you'll save money on fuel and depreciation, which should offset the additional maintenance costs and then some.
Just looked it up. Mercedes uses reinforced sidewall protection.
So... I'd REALLY like to get a spare "donut," but from what I'm hearing there are none that fit underneath the cargo area. Is anyone doing anything like this in a creative way? One idea is just to carry one in the baggage area in a box or something, but that seems lame. Looking for some options. Thanks!
I advise carrying a small tire patch/plug repair kit and a small air compressor just for emergencies. You can get both for under $20 these days.
Between that and AAA which costs maybe $50 a year, you shouldn't need anything else.
I am running 4 regular tires and carry this and a AAA card.
https://slime.com/collections/all-in...ire-repair-kit
Even the spare in the GLK350 has to be inflated before you use it.
The best I can describe... a thin piece of aluminum, which is shiny on one side and has that "cross-hatch" pattern on the other side, with a shape like a knife blade.
We live in a semi-rural area, where the "main" road to civilization is a two lane blacktop with not much traffic ... I'm completely perplexed where the tire (left rear) picked that up. That piece should have been laying flat on the road ... how it jammed itself into the tire will be a mystery
They key to how it got into your tire is that it's in the rear tire. Your front tire hit it, and kicked it up into a position where it contacted the rear tire with the point toward the tire and the "base" on the road, allowing the tire's forward momentum and rotation to do the stabbing.
