raise suspension
Old Apr 24, 2014 | 08:30 PM
sparrow13's Avatar
Mercedes global 2014
raise suspension
Hi, is there something to raise the suspension at least 3 centimeters? I would like 30cm between the ground and the chassis, my glk have 27 cm, thanks.
Old Apr 25, 2014 | 04:06 PM
drumminj's Avatar
'14 GLK250
You could increase tire diameter. Going to 235/55/19 (if you have 19s) would give you an extra inch/2.54cm I believe.
J
Old Apr 25, 2014 | 04:20 PM
sparrow13's Avatar
Thanks, I have wheels 19 with progressive tires FA 235/50 RA 255/45
Old Apr 25, 2014 | 04:26 PM
drumminj's Avatar
'14 GLK250
Sorry, I'm wrong on that. Total tire diameter would go up about an inch, but only half of that would be between the ground and the wheel hub/suspension. So that'd buy you half an inch/1.2cm
Old Apr 25, 2014 | 04:32 PM
sparrow13's Avatar
OK but, are you sure that is not a problem? Is there enough space between the tire and the shock absorber from the inner side?
Old Apr 26, 2014 | 02:48 PM
drumminj's Avatar
'14 GLK250
I've not measured, so I can't say for sure, but I wouldn't expect an issue increasing diameter that little, other than your spedometer will be off. I believe I've seen posts on here where folks went larger with their winter tire setup.
Old Apr 26, 2014 | 02:54 PM
sparrow13's Avatar
Thank you very much!
