Left air vent replacement?
Old Jun 28, 2014 | 09:27 PM
magendim2's Avatar
GLK350
The little chrome/black tab that adjusts the air vent position broke and it just flops around and can't adjust the left right movement. Do I have to replace the whole vent assembly? If so, does the assembly just pop out from the dash or ?
Where is the best place to buy a trim part like this? I've had my GLK350 for a couple of years but other than the 10K services, never had to do any repairs. It's got 63K on it so past the factory warranty.
I'm used to buying parts and accessories for my old BMW E30, but the GLK is my first Benz...
Old Jun 28, 2014 | 09:38 PM
Scadobe's Avatar
1975 450SLC 2012 GLK350
The vent has to be pulled out and replaced. It requires all the wood grain pieces around the steering wheel to be popped off. They come off easily, simple tension brackets hold them. The biggest problem is that the center vent needs to come off too, which can be achieved, just requires a bit of pulling and before it comes out make sure you push the plastic bezel back into place that surrounds the LCD screen, since there's a few plastic clips that hold it to the vent, it will want to come off with the vent.
Not to mention the black plastic bezel around the instrument/odometer panel. Seems crazy, but I've done it before. If you attempt this it's best to use plastic tools, the plastic bezel around the instrument panel comes off from the top first. It's important to not crack any plastic tabs, otherwise things will creak. I'd also tape off any part of the dashboard, soft part with painters tape, even the plastic tools can scrape it and leave scratches.
It's a bit of work, the pic shows why. If there weren't the extra clips that actually sit behind the bezel around the instrument panel, it would be a simpler removal process.
Old Jun 30, 2014 | 09:38 AM
bop11's Avatar
350 GLK, C280
My left and center ones broke at about 30k miles. Dealer replaced under warranty. If you are still under warranty get the dealer to do it.
Old Jan 28, 2017 | 09:29 PM
Larry_B's Avatar
2012 GLK350 4Matic
Here is a cheap way to fix this problem that works:
http://www.venttabs.com/
