GLK Interior light issue
Old Dec 12, 2014 | 10:53 AM
erlomd's Avatar
2010 GLK 350 4MATIC
My 2010 GLK is having an issue with the interior light (#7 in the supplied image)
the interior lights should all turn on when the door is open and turn off when you close the door...lately It does not...But, does turn on normally if you manually press the light button (#4 in the supplied image)...all lights work normally other than that...and the #2 button (in the supplied image) is disengaged.
all the settings on the dash/steering wheel control are set to turn on when the car door is open, courtesy lights are on...
anyone had any similar problems or know a way to fix?
I looked in the manual and found nothing...
I saw someone else was having a similar problem that the lights will not turn off!!! thats worse!!!
any help out there?
Old Dec 14, 2014 | 10:31 PM
erlomd's Avatar
2010 GLK 350 4MATIC
Well I guess it just fixed itself...seems to be working fine now...which makes me all warm and fuzzy inside knowing that I may have electrical issues
Old Dec 15, 2014 | 07:02 AM
eki912's Avatar
GLK 250 Bluetec
Door switch stuck to closed position ? Or was, and now free again, and works ?
Maybe wearing out and soon to be renewed ?
Old Dec 15, 2014 | 08:18 AM
erlomd's Avatar
2010 GLK 350 4MATIC
Very true...that's a good point
