Body Parts Backward Compatibility
Old Feb 19, 2015 | 06:07 AM
Poirot's Avatar
2015 GLK350 4Matic
Angry Body Parts Backward Compatibility
Who can confirm that the following body parts of the GLK are interchangeable across year models 2013 to 2015.
Our 2015 GLK350 4Matic was rear-ended and it's been impossible to get the following replacement parts:
1. Complete Rear Bumper Assembly
2. Tail Lamps Set
3. Quarter Panel Skin
4. Left Side-Step.
If the 2013/14 Models' Body Parts will serve to replace these, we'll really appreciate the information. It has been impossible to get the 2015 parts.
Best Regards,
Don Poirot.
Old Feb 21, 2015 | 09:39 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
You have an almost new vehicle. If rear ended, the accident was likely not your fault unless you were reversing. So make the responsible party get it right. Used parts & older model parts are ok but you should not have to do their homework. As to latter, I suggest you find an on-line MB parts supplier & do research. Year to year part numbers do not change if they are the same. Upgrades happen & thus p/n's do change. Good luck on the search. You can also check out carparts.com
