Just finished brake job on 2010
Old Apr 17, 2015 | 06:06 PM
cindyclk's Avatar
Just finished front brake job. If you have ever done a brake job, this one is as easy as it gets....only issue was getting an 18 torx E socket..bolts were little tough to remove...needed extension bar on socket wrench.
Ordered OEM rotors, pad, and brake sensor from Autohausaz....came to $320 shipped...includes new pad clips and bolts. I know that many some will post/ask why I stuck w/ OEM...they worked for me..quiet...I use Maguire's brake dust barrier to keep the wheels clean....so I just repeated the setup.
Calipers didn't need any service...wd40 around rotor hub and a sledge hammer worked....about a 2 hr job after I located the E socket.
