side marker light trouble
Old Apr 22, 2015 | 11:15 AM
cindyclk's Avatar
Here is my problem....side marker light error
tried to replace bulb as directed in manual...unfortunately, as I inserted the bulb holder w/new bulb, the socket w/2 wires got pushed forward. I can't get it back in place. I don't care about the light, I just want the message gone. I grabbed the 2 wires and spiced them hoping that by completing the circuit, I could eliminate the message...but no.
Any ideas?
Is there a fuse just for the side markers?
Am I thinking wrong jumping the 2 wires?
something so simple creating big problem.
Old Apr 22, 2015 | 12:18 PM
MBKLUE's Avatar
Yikes:
Any ideas?
You definitely did not do the right thing connecting the two wires together. You would need to connect a resistor between the wires with the equivalent resistance of the bulb to "compensate." Take it to the dealer and have it fixed properly.
Don't know if there is a fuse just for the side markers but you did blow a fuse.
Old Apr 22, 2015 | 02:12 PM
cindyclk's Avatar
I know that I will need a resistor to compensate...I'll try a led replacement rather than pulling the entire lamp out for the repair.
...no fuse gone...still power coming in.
Any other suggestions?
...no way will I go to stealership for an electrical fix.
Old Apr 22, 2015 | 02:46 PM
MBKLUE's Avatar
Yikes:
... Any other suggestions? ...
Yes, don't do electrical work.
Old Apr 24, 2015 | 09:52 PM
cindyclk's Avatar
Worked a little longer on the contacts...used emory board on all contacts...slid the bulb holder into loose socket...inserted both forward...all good now
Old Mar 1, 2022 | 08:32 PM
Phil 604's Avatar
2011 GLK
Any ideas?
I realize this is an old thread , but I'm having the same issue My problem is with the bulb holder pushed into the housing I'm unable to get it back out. Any ideas?
