GLK 250 Amsoil oil change
Old Jun 14, 2015 | 07:14 PM
sethwm2's Avatar
2014 GLK 250, W123 1981 300D 1985 300D Turbo Diesel
I am changing my oil next weekend. Already have a Mercedes oil filter/air filter/cabin air filter. I am ordering Amsoil... The Amsoil website recommends:
European Car Formula 5W-40 Mid-SAPS Synthetic Motor Oil (AFLQT):
http://www.amsoil.com/catalog.aspx?code=AFLQT-EA
Or
European Car Formula 5W-30 Low-SAPS Synthetic Motor Oil (AELQT):
http://www.amsoil.com/catalog.aspx?code=AELQT-EA
Mercedes dealer says they change with 5W-30.. can I use Mid-SAPS or should I stick with Low-SAPS 5W-30?
Most of my driving is highway 60 miles highway round trip per day for work.
Old Jun 14, 2015 | 10:17 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
If you have the OM 651 engine then you need to use a 229.52 spec oil only in your engine.
http://bevo.mercedes-benz.com/bevoli...begriff=229.52
I don't see Amzoil on that list. You might check with them before the investment. It needs to be 0-30 or 5-30 ESP oil
The older diesel can use 229.51 oil but you might be out of luck. The Amzoil 5-40 is on that list.
Old Jun 14, 2015 | 10:24 PM
sethwm2's Avatar
yeah I have the OM651 engine. Thanks for the advice.
HONDO250's Avatar
GLK250
AMSOIL is a quality product for the proper weight ,a safe guess is to match Mobil One ,referring to the manual concerning conditions in the area of your residence.
Since it late Spring , & your diesel engine start-ups are at time when higher temperature will probably be encountered.A safe bet is to match the proper viscosity that is recommended by Mercedes-Benz.60 miles of Highway Driving is different than local Stop & Go driving.
Highway Driving seems to be a positive in the 45-60 miles per hour range.
I recently traveled 8 hours of Highway driving at 45-70 miles driving //..above 60 miles per hour..fuel efficiency was effected...
With the proper synthetic oil ,you will be successful in your travels...
Old Jun 14, 2015 | 10:33 PM
sethwm2's Avatar
I would like to get the best possible oil.. something that would be considered Amsoil level.. would you recommend buying directly from the dealer? Order Mobile 5W-30 ESP online?
Old Jun 14, 2015 | 11:15 PM
sethwm2's Avatar
Is this correct?
Amazon.com: Mobil 1 5W-30 ESP Synthetic Motor Oil, 1 Liter Bottles (case of 12): Automotive Amazon.com: Mobil 1 5W-30 ESP Synthetic Motor Oil, 1 Liter Bottles (case of 12): Automotive
Old Jun 15, 2015 | 09:13 AM
formerjeepguy's Avatar
2015 GLK350
Check the dealer price on the 229.52 5w30 oil as it is comperable or cheaper than the mobil1 from amazon. Pick up a genuine MB oil filter while you are there as the aftermarket filters are crap. As a byproduct you will have an MB receipt should there ever be a warranty issue.
Old Jun 15, 2015 | 03:21 PM
HONDO250's Avatar
GLK250
The best answer is to be very Specific & go to MB SPECIFICATION SHEETS,find the best specification for your engine.
European, USA, & other countries.
There could be warranty issues & all lubricates can be found each specific engine,parts.
Match the specification to the product purchased.
Naturally Mercedes Benz will recommend MOBIL 1 in proper specification
after market filters use is taking a chance, "Knock offs"
Parts like oil filters ,use a Genuine MB oil Filter
The advice being given by other MB WORLD members is sound advice.
Old Jun 16, 2015 | 09:16 AM
oscaar12's Avatar
2015 GLK 250 o3 clk 430 09 c 300
When I purchase a new car, I always put in the deal that I get trade price on parts.I get MB oil at $10 and change and a filter around $20 I use their oil and filter so there is NO wiggle room for the manufacturer if I have an engine issue. frankly I can not see why anyone would use non MB parts in the service of their MB, Penny wise pound foolish as my Mom used to say.
Old Jun 16, 2015 | 05:31 PM
HONDO250's Avatar
GLK250
A purchase of oil does not need to be made at the Mercedes-Benz dealer.
I have as yet seen a MB Dealer reach into a box & take out individual containers of Mobil 1 Oil.
They use a 55Gallon drum measure it off.
A Genuine MB Filter is available From a Foreign Parts Supply Store.
I must admit I did my own oil changes at one time but I do not any longer .The DEF , I refill the tank with the right container that attaches ,screws in ,no overflow.
Some individuals purchase PEAK BRAND DEF & proceed using the empty Individual DEF Containers.I have not tried this product.
Short cuts are a money saving but the mechanic needs to be knowledgable.
I no longer use my Original MB Dealer, the mechanic I had "cut corners' Estimate & Service was very poor at premium MB Price.
There are many short cuts but be sure the o-rings are properly installed in the MB oil filter.
Old Jun 16, 2015 | 06:47 PM
oscaar12's Avatar
My dealer sells MB branded oil only
Old Jun 17, 2015 | 11:10 AM
cindyclk's Avatar
Just get some 5-30 Mobil ...one as posted above... and you will have no issues...Pep Boys etc.sells it for a lot less than what MB sells (just a synthetic oil that they repackage).
Old Jun 17, 2015 | 12:09 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Oh sure... just pour some canola oil in there and you're good to go.
If you don't know what you're talking about, please refrain from giving wrong advice on the forums. The MB Bluetec engines all have DPFs and all require ESP olis at a minimum, so MB *APPROVED* 229.51 or preferrably 229.52 spec oils are the only ones you can run without killing your rather expensive exhaust aftertreatment system. And, if you look at the viscosity charts for the GLK 250, unless you live in the middle of the Sahara desert you probably want to stick with a 5W-30 (or again, preferrably) 0W-30 oil. The M1 ESP Formula 5W-30 was actually formulated for gasoline engines (it even says so right on the bottle) despite the ESP and MB 229.51 approval, while the M1 0W-30 (that has both 229.51 & 229.52 approvals) is the best one for the application in the Bluetec GLK 250. This is what the bottle looks like:
If it's not on the MB 229.51 or 229.52 approved list at BeVo AND isn't the proper viscosity, don't put it in your GLK 250. MB 229.52 approved oils don't - can't - exist in a xW-40 viscosity. It's too thick by definition.
The only thing Amsoil has going for it is film shear strength and anti-wear additives. While this is useful in gasoline race engines where the ambient temperatures are always in the "t-shirt" range and the oil only has to last 300 km before you dump it, these same characteristics make it inherrently unsuitable for use in a modern MB diesel enigne. And, don't confuse Amsoil's marketing jargon - "designed for use in engines requiring [insert desired spec] oils" with "has the following BUILDER APPROVALS" [insert desired spec]. Only the second actually means that the oil was approved for use in your enigne. The first is a slimy and underhanded marketing tactic.
Old Jun 17, 2015 | 01:14 PM
HONDO250's Avatar
GLK250
Sound Advice,Points Clarified
A GLK350 ,is a Gasoline engine vehicle as stated.
The direction in the Thread is to give sound advice, Advertisements can have the hype necessary to purchase the AMSOIL Product.
The writer is quite correct to review all specifications...I use the Mobil 1 Product for my Diesel MB GLK 250.
As stated before ,Car owners in Canada, EU or other Foreign Countries may use different blends.The key issue is warranty & emissions..the general rule is to safely say the number model noted on the Mercedes Benz Vehicle can be quite different.
Certain Countries do not require emissions equipment or safety glass.
In the USA, the vehicle is not released to the new owner until the vehicle is in compliance...My MB GLK 250 has run flat tires, the Canadians a compact spare, flat repair kit,compressor & other equipment .
The only thing Amsoil has going for it is film shear strength and anti-wear additives. While this is useful in gasoline race engines where the ambient temperatures are always in the "t-shirt" range and the oil only has to last 300 km before you dump it, these same characteristics make it inherrently unsuitable for use in a modern MB diesel enigne. And, don't confuse Amsoil's marketing jargon - "designed for use in engines requiring [insert desired spec] oils" with "has the following BUILDER APPROVALS" [insert desired spec]. Only the second actually means that the oil was approved for use in your enigne. The first is a slimy and underhanded marketing tactic.[/QUOTE]
Old Jun 17, 2015 | 01:50 PM
oscaar12's Avatar
A CDN GLK 250 has no spare only a pump and a can of crap. No runflats.What happens when you are in the middle of no where at 4AM and some grumpy Redneck tow truck driver shows up to help you and the tire is junk. Great thinking Mercedes!!!!
Old Jun 17, 2015 | 02:47 PM
Diabolis's Avatar
The OP was asking about oil for a GLK 250 - that's the diesel. All of the ones exported to North America have the DPFs and thus require very low SAPS, MB 229.51 or the new MB 229.52 spec approved oils.
Just for the record - the Canadian ones don't have a compact (or any other kind of) spare - we have a tire sealant kit and a compressor.
Old Jun 17, 2015 | 02:55 PM
Diabolis's Avatar
Actually - the sealant / compressor combo works remarkably well, and seeing as there are no TPMS sensors in the wheel to foul, any resuidual gunk is easily washed off when you get your puncture repaired the next day. All you have to remember is to buy another can of sealant from MB before you get a flat tire again.
I for one am happy that we don't have run-flats like in the US - the ride on those is absolutely HORRIBLE.
Old Jun 17, 2015 | 02:57 PM
HONDO250's Avatar
GLK250
The Great Run Flat debate
My owners USA MB GLK 250BT Manual has the section about the space is laid-out for Canadian Owners...The MB WORLD Thread ran about the options that MB owners with Run Flats...
The Special spares, carriers etc...
At this time ,the replacement of a 235/50/R-19 MOE Run flat is limited.
Any run flat tire will be expensive , a replacement is 4 tires .
The Stock tire the Dunlop Grandtrek 235/50/R-19 availability can be limited in certain areas...which can answer your question: In the middle of Nowhere replacement??Though the Dunlop may get the driver 40-50 miles , the tire most likely will need replacement if it is a side-wall damage..& extended travel will render the tire not usable,beyond repair...
The Mercedes Dealer probably has the tire at $$$ Mercedes Tire Price.
My best thought will be to repair the puncture far off the road. & get to a tire dealer to remove the tire, patch & plug..."hopefully"
The Dunlop Grandtrek is listed as all-season with the notation "OK to drive in Light Snow" It is not a winter tire & in a snowy region of Canada , don't drive.
I replaced my Dunlop Grandtrek MO tires already with another brand of tire.
Still the size 235/50/R-19 is limited , I put Pirelli's on my MB GLK250 BT...I will stay off the winter roads until clear....use chains ,perhaps...
My selection was a Pirelli PZero MO 235/50/R-19 99W ( Summer Tire)
They have been great but not in Snow at a low temperature...
Maybe in the years to come , more options will be available ,right now everything is fine....If I move to a Snowy area like Maine, Canada, I would need to another set of tires for winter driving. All season tires cannot replace Winter or Studded tires ...My Sister in Maine puts another set of tires for her 4x4 Toyota, her husband does the same on his Toyota 4 Runner..A fact of life....location.location...
Old Jun 17, 2015 | 07:50 PM
2016 GLE300d 4Matic
Nothing like watching a thread get hijacked to discuss tires. A worthy subject but jeez, start your own thread - then whine.
I posted the link to the Bevo Mercedes 229.52 list above. Your oil for an OM651 engine needs to be on that list. Anything else is threatening engine abuse and warranty chucking. I've seen our local OReillys Auto carrying the Mobil 1 ESP oil in 0-40 (for gas) 5-30 and 0-30 for gas and the OM651 engine. Walmart will carry it if you bug the customer service folks. Then you pay $34 or so for 5.5 quarts. The oil filter (and oil) is available from Amazon. Search for the best deal in the exact oil you need. The oil filter should be a fleece filter not just paper, the Hengst, Mann and Bosch are all good and OEM. You don't need to use the dealer and their prices unless they match the price.
Old Jun 17, 2015 | 09:27 PM
HONDO250's Avatar
GLK250
mjhawkins2346
Sorry for the thread confusion subject mix-up Thread should have been directed to Tires not Oil.
Options concerning proper oil use & specification concerning the right filter .
You have far more experience in the ownership of a 2010 MB GLK350 Class vehicle (Gasoline)& have had experience in problem solving.
Old Jun 17, 2015 | 09:45 PM
oscaar12's Avatar
I am NOT whining, just stating a fact. The other person brought up the tire statement,
Sorry I will delete this forum from my computer just for you .
Old Jun 18, 2015 | 03:13 AM
sethwm2's Avatar
holy crap this thread got out of hand.. Thank you everyone for your input.. ended up going with MB branded 229.52 spec from the dealer.. guy there said he thinks its just MB branded Mobile 1 5W-30 ESP anyways
Old Jun 18, 2015 | 01:09 PM
HONDO250's Avatar
GLK250
sethwm2
Mercedes -Benz Owners are very precise about threads & I frequently get corrected for not staying on track with the subject...
Old Jun 18, 2015 | 03:44 PM
Diabolis's Avatar
Everyone take a deep breath... we are all friends here exchanging ideas and sharing knowledge. And, if you think THIS got out of hand, you should see some of the threads on the C63 forum or on Bimmerpost...
Old Jun 18, 2015 | 07:12 PM
sethwm2's Avatar
I can imagine on C63 threads and BMW forums it would get rowdy.. But I figured in the GLK forums especially in a thread posted about a nerd and his diesel oil change that it would be a little more calm .. I am 24 years old, but I am use to the slow calm roll of the W123 forum over at benzworld.org nice older people for the most part that don't seem to get their feathers rustled too easily. I have 575 posts in at benzworld.
