GLK 350 4 Matic in the snow
If money is no object, then Michelins is the top choice.
To be clear, my next tires on my GLK250 will be the Yokos. I'm currently squeezing every last mile out of the OEM Dunlops. They're supposed to essentially be "run-flats" but they're technically just more puncture resistant. I digress...
The Yokos I had on my last Merc replaced the Michelin Pilot Sports that wore out on the rear in about 25K miles. And as they wore down they became increasingly noisy.
The Yokos I put on were an immediate improvement in comfort (basically silent), extremely grippy in the wet and dry, and actually took me into North Carolina's ski area during the middle of a blizzard in 2013 where we had almost 2 feet of snow overnight. My C300 was not 4Matic, but it was a 6spd manual. I felt like I was driving a venerable all-wheel drive vehicle.
I kept the Yokos on the C300 for nearly 18K miles before I trading it in (big mistake, i know) and in that time I did not notice any discernible wear. Coming from the Pilot Sports, that shouldn't be surprising.
They also did not need constant balancing or topping off air, as did the Michelins they replaced. I also noticed a slight fuel efficiency improvement, to where on a long freeway roadtrip I could get 31MPGs.
YMMV
I've had several loaner MBs equipped with the Scorpion Verde + when my Bluetec was in the shop on various occasions and have always found them super quiet, grippy, linear, and sporty without being harsh. The higher mileage warranty is a bonus.
This isn’t Alaska. Most GLKs are awd, combine with mild northeast winter all season tires are more than adequate.
I’d own 32 tires if I took this approach
While I'd love to afford a complete set of winter wheels and tires, I just don't have the funds or the space to dedicate in my garage. In my 21 years of driving through all 4 seasons with (you guessed it) all-season tires, I've never gotten stuck or wished I had dedicated winter tires.
Obviously I am just one data point and one opinion, so YMMV.
In conclusion, drive more worry less
If so, get a good set of all-seasons (found a great deal on Kumho Ecsta PA51 recently, for example) and you should be OK. They do plow the roads up there after big storms, so as long as you plan your driving accordingly you shouldn't have to put on any chains.
FWIW, I had a C300 Sport that I took on a skiing trip in the middle of a blizzard several years ago. My only "mod" was a brand new set of Yokos with TONS of tread. I never got stuck once, not even when 6+ inches of snow was dumped overnight. The traction control along with great tires works wonders. In your case, with the extra ground clearance the GLK has, you should be fine. Be gentle on the throttle and especially the brakes.
