2010 GLK350 Aftermarket hitch CURT wiring
Old Jan 22, 2016 | 09:52 AM
johny-rock's Avatar
2013 C63 AMG, 2010 GLK350
Hi to all,
I installed a CURT hitch on my 2010 GLK350 and everything went well but now I am puzzled with the wiring for about a week now. I have a Canadian car with daytime running lights if that matters.
The recommended converter is CURT 56200 which I installed first. LEFT (yellow) and RIGHT (green) turns signals work perfectly. However, my TAIL/BRAKE (brown) stays always ON. I am pretty sure I used the correct wire (pink wire on driver side harness).
When testing this wire (pink MB harness before the converter) with a lamp :
- Step on the brake : High intensity
- No step on the brake : Low intensity
When testing converter output (brown) with a lamp :
- No step on the brake : High intensity
I called CURT technical support and spoke with a technician over there. By the way, they have an amazing unit and they sent me a replacement unit very quickly. They also informed me that the 56200 is discontinued and sent me a 56236 unit.
Unfortunately, the new 56236 have exactly the same behavior so I don’t suspect a bad converter anymore.
You guys have any ideas?
(Attached is the wiring diagram from Xentry)
Thanks for your help !
