Please help 2010 GLK350
Old Apr 12, 2016 | 06:32 PM
fzrto's Avatar
GLK 350
about 1 month ago my instrument panel started going crazy. I would try and start the car and a number of error messages would appear and the speedometer would start to blink and everything went nuts. I was still able to turn the car over and drive it. In the last month this is starting to happen frequently and today the instrument panel went crazy again and the car alarm went off and I could not open/close the doors using the FOB. Has anyone ever experienced this and if so please help
Old Apr 13, 2016 | 10:04 AM
bop11's Avatar
350 GLK, C280
Did you ever put a new battery in the vehicle? With all that it sounds like a low battery spiking the electronics during a high current start.
Old Apr 13, 2016 | 07:17 PM
fzrto's Avatar
GLK 350
No. I have never replaced the battery. It's odd because when I do get it to turn over the car starts as if nothing happened. If it's the battery I would have thought that the start would be slugish
Old May 4, 2016 | 10:13 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
You need a mechanic with the Star system or a dealership to pull codes and test systems for you. Otherwise it's total hit or miss. This stuff is too complex and one simple part failure or loose ground can make the car go nuts.
