Brake Pad Sensor didn't do anything, caliper bad?
Gordon
There is usually quite a bit of material left on all pads when the sensor is cut. If the two wheels wore that much differently, I would look for a problem in the brake lines or master cylinder. Check to see if the opposite rear pads are much smaller than the other rear, although the rears wear much slower. If so you are only using one circuit to do most of the stopping. Could be a problem with the master cylinder of equalizer.
If the two pads on the same wheel are wearing differently, I would suspect that the caliper is hanging up. Did you replace it or have it rebuilt?
Sensors on one pad for the front and the back has been a very successful system for many years. Although the cost of the sensor is less than a buck, saving 2 per car, for a million cars per year adds $2 million to the bottom line per year.
Ford took the electrical contacts out of the radio on-off switch back in the '70's. The knob turned the volume to zero and the radio went off with the ignition key. Save 20 cents per car. Two million cars per year, $400k savings. No Harm done, the guy who suggested it got ???.
The outboard pad on my front right caliper wore faster than the inboard pad. The pad sensor is mounted only on the inboard pad. So I started grinding on the outboard pad while the inboard pad still had sufficient pad that the sensor didn't do anything. Had they both worn equally, I would have gotten a warning before I ground the rotors.
As for left vs right, overall the same although on the left side, both the inbound and outbound pads wore evenly. So I see a problem with the right front caliper since I'm not getting even wear. Based on how it is mounted, I wouldn't think there is a binding issue where the caliper is not moving freely. But I could be wrong. There are no caliper pins to grease/lube. On other cars, that has been what has caused uneven wear between the outboard and inboard pads.
