Service reminder
I have a Service reminder popping up every time I turn on the engine.
I do realize I am due soon for Service A.
I have a BlueTec diesel and I wonder if I can exceed a little.
I did schedule an appointment at MB, but I am concerned if this is related to urea tank as well. I read other day day the thread that the message was in such a case "you have # of starts left". Am I right? Or I should go as per odometer message right away?
Don't want to end up with car on a side road.
Thanks a lot!!
IF you let the fluid run low, after the last number of starts, you won't be able to drive it anymore. So yes, you need to fill it promptly. Your owners manual will also tell you that once filled, just start and drive the car and it will reset the message on your dash. The stealership will tell you that you need to come in and have them reset it. That is BS. Also the dealers tell you that you have to buy Mercedes urea. That is BS as well. All the diesels that use DEF use the same solution.
Good luck and happy motoring!!!
