Location of External Temperature Sensor
Old Feb 9, 2017 | 10:49 AM
LiftOff's Avatar
Magic Toaster Oven
My ambient temperature sensor is off by quite a bit. It looks like it might be loose, dislodged, or the connections rusted.
Anyone know where it is located so I can fix it?
Old Feb 9, 2017 | 11:46 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
It's behind the grill and it's plastic for the most part so no rust, it might be dislodged and sitting to close to the radiator or another heat source.
Old Feb 9, 2017 | 11:54 AM
LiftOff's Avatar
Magic Toaster Oven
Thanks! I will take a look tonight and see what's wrong with it.
Old Feb 10, 2017 | 10:51 AM
AzCamel's Avatar
Take off the front lower splash shield and you can see it
Old Feb 11, 2017 | 09:43 PM
LiftOff's Avatar
Magic Toaster Oven
Looked behind the grill but couldn't see anything.
Took some photos, could you point me in the right direction?
So behind the grill.
Down there somewhere?
Old Feb 12, 2017 | 01:12 AM
AzCamel's Avatar
Behind the lower grill , to get to it you must get under the car and take the front part of the splash guard off which is held on by 10 or 12 screws. Then just look up from under the car and you see it, you can only see the pointed tip of it by looking at it in front of the car.
