car wont start
so i tried to start my car today and i insert my key, turn it to the on position, all the instruments and lights turned on as normal. radio works and all. when i tried to start it, nothing. no lights dimming, no sound of the starter turning over. when i try to start it, nothing turns off, the radio kept playing with no interruption for example.
side symptom, the windows do not lower even when the key is in the start position as it usually would.
I tried jumping the car and it made no difference. put a meter on the battery and it read 12 volts the entire time, no dipping in voltage. the key fob still works and can lock/unlock and open and close the trunk so i dont think its a key fob issue.
there are so many reasons for the car to not start based on my google but i couldnt find the exact conditions that I had.
Any ideas?
UPDATE: it is the ESL. is there a DYI for replacing the ESL unit?
this thread may also get you started
https://mbworld.org/forums/c-class-w204/621422-esl-problem-help-needed.html
I find sometimes my key will turn on all the auxillary systems but not start the car. I turn it off, take the key out and try again. It usually starts just fine. When I asked about this I got the complex answer I shared. In a way, I was sorry I asked. I look back fondly to turning a key which closed a relay and away we went.
Your battery at full charge should be between 12.6 and 12.76 volts.
Charles.soori who we are lucky enough to have as an active member here, has solutions for these bits when the break. its in the thread linked in the 2nd post.
I agree with Hawkins, its amazing these things even start, they really turned something simple into something needlessly complex.
