Yaw sensor
Old Feb 4, 2018 | 01:21 PM
richsmoke's Avatar
2010 GLK 350, 4-Matic
Yaw sensor
Where is the Yaw sensor located on a 2010 GLK 350??
Old Feb 4, 2018 | 08:48 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Looks like the stability control sensor (007-542-04-18) is underneath the carpet of the front seat.
Old Feb 11, 2018 | 03:37 AM
richsmoke's Avatar
Thanks for that Johnny! Any idea which seat? I would hate to remove one only to find out it was under the other.
Old Feb 11, 2018 | 04:14 AM
JohnnyC's Avatar
Says it is under the driver seat. You need to remove the entire front seat to get access to the vent area. Remove the battery so no power is going to the airbag unit, consequently if not done you will get an airbag deployed/failure message in the instrument cluster that is not removable without a scanner.
