P261F CEL code on 2014 GLK 250 BT
Any suggestions for other parts that could be involved greatly appreciated
I was about to start replacing vacuum lines when without any further intervention the CEL stopped coming on, no more codes!
The only thing I can add was that the timing was at the end of winter, so warmer temperatures may have played a part.
BTW the car throughout ran fine, mantained correct temperature. I must have driven it with the CEL on for 6 months and only bothered to get it fixed as I needed a State Inspection. Now 6 months later with nothing else changed still no CEL or codes. Go figure!
Vacuum solenoid actuated water pump is on mine and I guess it act as AUX pump function in starting.
Some reason the water pump it self (not OEM) didn't fix the issue.
This mechanic gives a good description and diagnostic approach for the issue:
Such a relief to finally see the CEL gone! Good luck out there.
