MB maintenance special tool list?
Old Jun 15, 2018 | 09:38 AM
a64armt's Avatar
2018 E400 4matic coupe / 2015 GLK 250 BT / 2008 F250 Diesel
Excuse my ignorance if this is already posted somewhere, but is there a list of unique or special tools and test equipment (ST&E) for Mercedes Benz (GLK) maintenance? I have done some searches here and found various threads on specific tasks, but no list that might help someone trying to build a toolbox to support their car. I am not talking about generic hand tools found in your average tool box, but the MB unique items like Female Torx (E-Torx), oil filter wrench or even the service reset tool/scanner. I found a posting on another site that provided the examples I provided.
Perhaps there is already a sticky I have overlooked.
i have found these on Amazon and will continue to add. The initial investment can seem daunting but worth while if I continue to perform most basic maintenance.
thanks
OJ
Old Jun 15, 2018 | 01:11 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
-16mm Engine mount tool (aka torque adapter)
-o2 Sensor Socket or handled tool
-Pulley Holder. Need for major engine work, but also necessary for turning the crank on diesels.
-Clic-R pliers (AKA german hose clamp pliers). Used for air filter hose clamp removal. Cheap ones are like $10; Must have tool.
-Fuel line pliers. For servicing fuel filter, connectors, etc.
-Mercedes Sealant dispenser 112-589-00-25-00, not necessary to have, but makes sealing the engine and differential easier. Sealant is 003-989-98-20-10
-1/2" drive, 41mm or 1 5/8" crowsfoot wrench. For inner tie rod removal and install.
-3/4" square drive, 32MM or 1.25" 12 sided socket. For rear Axle Nut
-Claw socket for interior ignition switch. Vital tool for any dash work.
-wiper arm tool, any cheap one will work. You need to use this tool to do stuff relating to the front fuse box or brake booster.
-Torque wrench. For installing suspension components, wheel bolts, glow plugs, spark plugs, sensors, etc.
-Electrical disconnect pliers, made in Japan by KTC or MERRY. Very useful to removing small stubborn connectors
-Terminal disconnect tool. For wire repairs, modifications, or installation
Old Jun 15, 2018 | 03:30 PM
a64armt's Avatar
Many thanks for the list!
OJ
Old Jun 15, 2018 | 03:39 PM
JohnnyC's Avatar
I will keep adding/updating as time goes on.
Old Oct 21, 2019 | 01:40 PM
reesesboot's Avatar
2010 GLK 350 RWD
Has it been confirmed that the engine mount tool works on these GLKs? I know there was that guy selling customized versions of the tool (has a youtube video), but I haven't seen anything on the board commenting on the standard tool working.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
