GLK 250 Turbo Failure
As a temporary fix, I cleaned the exterior of the hose with denatured alcohol to remove dirt and grease. Then I glued the tear shut with CA glue (superglue). Finally I wrapped the hose with heavy duty duct tape. The fix has held for two days with no return of the engine code. I'll replace with the new hose as soon as it arrives.
A few notes for anyone who is attempting the repair:
--There seems to be a bunch of alternate names for this part (intercooler hose, outlet pipe, charge hose, etc.). Just search for the part numbers above: Driver Side (204-528-25-82), Passenger's Side (212-528-08-8)
--The only way to access the hose is underneath the car. You must remove the splash shield in order to see it.
--There are two hoses that could be split, one on the passenger's and one on the driver's side. The driver's side is black and I think is more prone to splitting. The passengers side is red and made of a heavier duty material (thus the higher cost for a replacement).
--The hose is connected with a "Henn-type" connector. I had never seen one before and had no idea how to remove it. I could find nothing online explaining how to remove. If you search "Henn-type" you'll see that there is a special tool available. I just used a flathead screw driver. There are basically two metal wire clips that you pull out slightly, releasing the hose. Luckily I didn't break anything.
--Finally, I had a weird transmission issue that coincided with this. There would be a rough downshift from 3 to 2 to 1 whenever I stopped. I think it was probably unrelated, but I guess maybe the TCU could have adjusted itself due to a change in the way the car was handling without the turbo??? In any event, I reset the TCU and it appears to have fixed the problem.
Thanks!
He showed me the tear (i will post a picture later), i cannot figure how the hose could crack (neither could the mechanic) and I could not figure how the previous mechanic could not catch it (its pretty visible).
He is asking for $430 (parts + labor). He said the turbo is fine, no issue with it.
I didnt get it fixed because I wanted to understand the vastly different diagnosis.
How could the previous mechanic figure out that there is a play in the shaft without opening up the whole engine compartment? Does Mercedes have some kind of diagnostic tool that can measure shaft play?
Appreciate your inputs!
Hi, I have a 2014 glk250 that had the same trouble TWICE. The intercooler hose drivers side kept RUBBING a hole into it's self. The mechanic explained to me there is a sharp edge on the unibody frame the hose rubs against,
so his fix was to file away the rough edges. This happened at 60K miles and I now have 120K+ and all is well now. The repair cost each time was about $400 labor and parts.
FYI.
Old part number is 204-528-27-82.
https://www.mbonlineparts.com/oem-pa...ose-2045280000
Filippo
Filippo
The 2.1L diesel Benz is a solid motor with, more importantly, sold peripherals. Easy to work on as well. But the knowledge of the average Benz owner is pretty low, and certainly low in the modding world. No market for the product.
I'll also add, once you pull the pipe you'll quickly surmise that it is a specialty piece that would take some effort to replicate in the aftermarket. I suspect, once you put in a new one, it will last you for 60k miles or so.
Filippo
A new charge pipe will last you quite well, just make sure it's not rubbing or touching anything it's not supposed to. That's what seems to be causing premature failures more than anything else; I'm on the original pipe at 121k miles...
Mine had two tears, parallel to each other and about an inch apart, 1 to 1.5 inches long. I was previously tuned and I think this contributed to the hose failure.
I did a small research, then I found that GLK 220 and GLK 250 have the same engine OM651. I would like to confirm if I can buy the part Inter-Cooler Hose Product ID: 204-528-00-00, located in USA for GLK250.
Does it fit into my CLK220?
Best to make sure before you buy.
Edit: For an easy removal/installation of the hose, pull the center of the locking clips all the way out. When the new hose is in place, simply push the center pin back in place and everything will be lock. Also a photo of the metal slowly digging is way through the hose.
Definitely a satisfying repair.
