Need audio upgrade advice on my 2012 GLK350
Old Jul 10, 2018 | 01:31 PM
frogjovi's Avatar
2012 GLK350
Hi Guys,
New to this forum. I have a 2012 GLK350 w/o HK audio and I can not bear the audio any more.
Can I buy the original HK amplier and aftermarket speakers to install? Is that a easy job?
Thank you so much!
Old Jul 13, 2018 | 08:57 AM
Mmr1's Avatar
2013 glk 350
Changing the head won’t help much, you need more than that. First try the hidden EQ in Engineering mode, push, #, hang up and star all at the same time, you should find a 4 band eq. That will only help a bit. What will help are better speakers , a sub and power amp hooked to the Audio 20. I used an Audison 8.9 bit amp , and Hertz 6.5 xl and a sub with the audio 20.
