Curt 56146 trailer hitch 4 way wiring install into 2014 Mercedes GLK250
I needed a fuse tap and some wire to complete the install. I also covered the wire with wire loom just for protection and presentation.
Wiring is as follows:
CURT UNIT --------------------------------------------------MERCEDES
WHITE AND RED (ground) ---------------------------- Vehicle chassis ground
BLACK (12v power)-----------------------------------------FUSE TAP AND FUSE 76 (socket rear) at rear fuse box
GREEN (passenger turn signal)-------------------------BLUE at passenger side light connector
BROWN (taillight signal) ---------------------------------Light blue/ Blue line at passenger side connector
YELLOW (drivers side turn signal) -------------------- PINK at drivers side light connector
The unit is meant to be installed on the drivers side but I installed it on the passenger side under the tail light connector. Because of this i used the extra green wire to extend to the drivers side light connector, that's why thew wire is also green and not yellow.
And here are a few pictures:
Appreciate any help. Cant find a 2015 GLK250 tail light wiring diagram. Thanks.
