transmission mount torque spec
Old Nov 14, 2018 | 01:07 PM
hawknight's Avatar
11 GLK350 4Matic
2011 GLK350 4matic has vibration when coming to a stop and at idle. Will replace rear transmission mount this week. Greatly appreciate if someone can clarify the torque spec for bolts of crossmember, mount to crossmember and mount to transmission. Thanks.
Old Nov 14, 2018 | 02:41 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Bracket to vehicle chassis bolt:
M10 x 1.5 - 20mm with self contained washer
External Torx 12
003-990-08-03
50Nm ~ 37 ft-lbs
Transmission mount to transmission body bolt:
M8 x 1.25 - 30mm
No data
910143-008003
28Nm ~ 20.5 ft-lbs
Bracket to transmission mount nut:
M8 x 1.25
10mm Hex
000000-003175
28Nm ~ 20.5 ft-lbs
Don't forget to alternate cross tighten as each set is grouped as 8 bolts, 5 nuts, 4 bolts.
Old Nov 14, 2018 | 05:52 PM
hawknight's Avatar
11 GLK350 4Matic
Johnny, thanks for the spec. Do you have data for engine mount bolts and the flexdisk bolts? While doing the transmission mount, I may need to replace those as well depending on the wear condition. Thanks.
