Power liftgate not closing
I have a big problem now. The liftgate (or rear hatch) on my 2010 GLK350 was working quite slow for a long time. I've always thought about checking the hydraulic and filling if necessary. This is the same case with my 2010 GL as well, so I was stalling this for nicer weather.
But yesterday the GLK's liftgate refused to close.
It works as it should (slower than it should actually) but at the last inch, it stops and opens fully again, just as if something's obstructing it OR it doesn't have the power to go the last inch and lock properly.
Any suggestions are more than welcome. My to check list:
1) struts
2) hydraulic status
3) motor
4) sensors that stop hatching
Thanks a million for your neverending support
I had no idea about it being electric and all that.
I don't have a charger but can buy one for sure. In another topic, someone has suggested that it might be the struts. What do you think?
Is there a guide for diy replacement for the struts or motor? Struts should be fairly easy but I'm not sure about the motor...
Battery part is easy, I'll just get myself a battery charger and try when its attached just as you've written. Is a jump starter what I should be looking for or a battery charger is something different?
