Help! High needle on temp guage?
I've found a 2013 GLK 350 4matic with 10k miles, it was a doctor's wife's car and maintained well however, the needle on the temperature gauge reads just over thr half way point.
MB mechanics say this is common on these vehicles, can anyone verify that? I've never seen a temp needle over the half way point on a vehicle.
Picture is a little fuzzy, but it's the left gauge cluster, right needle.
manballoGLK (06-13-2019)
My temp gauge reads just around 90 if I remember right. I would say that if it isn't creeping into the red or above 100 you should probably be OK. Mine is older though so I don't have the same gauge cluster as you do.
Welcome. Now relax, your engine temp is normal. The needle appears to be right in the middle of the normal operating range when everything is warmed up.
If you were having overheating issues, you'd know it right away. The instrument display would tell you in no uncertain terms. No warning lights or messages = motor on.
And a 2013 with only 10K miles? You likely found a gem, congrats.
The following 2 users liked this post by andreigbs:
Bozzy J Winters (06-13-2019),
When at normal operating temperature mine moves between 90 and 92 degrees Celsius. It had me a bit concerned because my previous diesel glk250 would stay dead on 90 degrees. Your temperature is completely normal.
HELLO I HAVE A GLK350 2015 AND SINCE I GOT IT, THE TEMP GAUGE READS AROUND 85% ... LIL WEIRD BUT THANKS FOR THIS POST HOPEFULLY WILL HELP ME UNDERSTAD WHATS GOING ON.
Looks fine to me. That is about what mine runs at.
