Testing motor after ESL replacement.
Old Jan 16, 2020 | 07:40 AM
LadyS's Avatar
GLK350
I’ve watched through several video tutorials, and read the few on here about testing the new ESL motor before re-installing the steering column, but have a question.
All of the tutorials advise to disconnect battery *before* disconnecting the airbag, to avoid an SRS code.
When testing the new motor, simply by plugging it in, and turning the key, do I need to attach all of the additional harnesses to attach the air bag?
Do I avoid the srs issue by only turning the key to “on”, and not trying to start the car?
or does the stored code reset when I disconnect the battery a second time to finish the final assembly?
As always, thank you!
Old Jan 18, 2020 | 04:54 PM
LadyS's Avatar
GLK350
Well, just to put the answer out into the ether.
Connecting the battery without the airbag plugged in DOES give you a malfunction code.
