No ESL?
Are they locking the column in another way? This model has the electric power steering setup. Is that why it doesn't have one? Or are they locking the column from inside that assembly? And if so, does that mean that it's likely the ignition switch that has failed? Or is there something else I am missing?
Thanks in advance.
Had it previously made the buzzing sound, and has recently stopped? Perhaps they wired in an emulator, and simply crammed a foam block into the steering column? My ESL is no longer mounted into the column, and is simply snugly zip tied up under the dashboard after I replaced the motor earlier this year. It doesn't have to be in the slot, or even actually lock the steering column. It just has to be functional.
