Anyone put a CANOE on the roof of their GLK?
Here's a pic of our camp north of Toronto where it snowed opening day in May. Don't expect to be towing our vintage Airstream with the GLK LOL but may throw on a hitch once I get my trailered speed boat done, that's a question for later. Right now I'd just like to get a canoe up on the roof and confidently maintain highway speeds with no damage.
Another question: What is the best way to store the key to keep it secure and dry while out in the water.
first. Buy the roof racks for MB.
second. Buy aset of Thule quick loop tie downs for either side of the hood. (They sit inside) https://www.thule.com/en-ca/winter-a...strap-_-530999
third. Have the straps going in opposite directions (front in back) and tighten. ie. the ratchets should be on opposite sides of the car
fourth. run a rope through the front bow of the canoe, then each end of rope through the quick loop. Then take the rope ends tie a series of half hitches to itself to secure it. If you don’t want the ends flapping wrap in black tape
When do those two things above there’s zero need for a rear tie point.
I’ve had used this method for countless trips on the highway storms and all and never had an issue.
second. Buy a set of Thule quick loop tie downs for either side of the hood. (They sit inside) https://www.thule.com/en-ca/winter-a...strap-_-530999
Didn't know about those quick loop tie downs. Appreciate the link!
Makes perfect sense and since the GLK hood latches seem pretty stout (plus as you said you've done this countless times) it's certainly worth a try. Our 16 ft Prospector canoe isn't very heavy (kevlar/fiberglass mix) but it will catch the wind if not kept pointed straight.
Curious though about your comment on putting straps going in opposite directions (front in back.) Are you referring strapping to the rooftop crossrails in an X pattern instead of directly over? I think I'll ratchet them down across the upside-down canoe. I do have the MB crossrails. They have a good, snug fit and I'm space them apart as far forward and aft as they can go, which will also keep the canoe from jackknifing on the roof. You're right, I don't think I'll need a tie-down at the rear, at all!
Looking forward to giving it a try when we go up to our camp in the Kawarthas this long weekend. (Will post pics)
Hope you have a well-enjoyed weekend too!
re. the strapping.
on the front crossbar have the tie down/ratchet part on the left or right side of the canoe (I put a piece on an old yoga mat to protect it or a piece of an old blue foam camp mat has worked in the past)
on the rear crossbar have the tie down/ratchet on the opposite side of the canoe.
In a bad cross wind, having opposite anchor points will prevent jackknifes
For the quick loops, here’s an image that illustrates what I do.
***make sure you tape any excess ends. The sound will be deafening and worse, it will mar the finish on the paint on a highway run.
