Torques spces For Rear Axle
Old 10-01-2020 | 12:24 AM
shadowflare99's Avatar
2011 GLK 350 4Matic
Hi guys
I have a GLk 350 2011 - with Sport Suspension - I need to replace the rear Shock absorber and the rear Coil spring AND the reluctor ring (impulse ring)
I need to know what is the torque Specs everything on the rear axles.
The only thing I found it's this :
Rear brake caliper mount hex bolt:
M12 x 1.5 - 35mm
18mm
124-421-05-71
120Nm ~ 88.5 ft-lbs
Rear floating caliper guide shoulder screw:
7mm hex key
000-421-08-18
34Nm ~ 25 ft-lbs
Rear hub axle flange nut:
M26 x 1.5 - 17mm
32mm or 1¼"
000-353-13-73
350Nm ~ 258 ft-lbs, then stake
Rear wheel bearing carrier flange bolt:
001-990-42-03
70Nm ~ 52 ft-lbs
(ref : https://mbworld.org/forums/glk-class...que-specs.html )
but nothing about the all the other thing for rear behind the Knuckle ASsembly :
the Control Arm, Strut Rod, Front Lateral Arm, Rear Lateral Arm
Also in summer 2021 i replace front component, replace all arms, suspension, coil, absorber, so do you have it for the front too
thank you
Old 10-01-2020 | 08:56 AM
andreigbs's Avatar
GLK 250
Not sure about what all those specs should be, but in general, suspension is best replaced across both sides of an axle at minimum or at all 4 corners at the same time for maximum effect.
Then you'll need a 4-wheel alignment. Let us know how the summer of 2021 shaped up to be, many of us are looking forward to it
Old 10-01-2020 | 01:39 PM
2011 GLK 350 4Matic
I Know it's preferable to replace the suspension both sides at the same time, and doing an alignment, .... the main reason is, for now, the Urgent problem, I need to replace the reluctor ring, on the rear-passenger side.
this is why I was looking for the torques specs to assemble everything correctly ... because now I don't have any ABS - ESC - BAS etc.
I don't run my GLK often (less than 3500 km per years) so this is why I will take my time to do the rear, and next summer the front suspension ....
Old 10-01-2020 | 02:02 PM
andreigbs's Avatar
GLK 250
See this vid, it may contain important details, maybe even torque specs. It is on replacing the reluctor ring.
Old 10-09-2020 | 11:00 PM
2011 GLK 350 4Matic
https://youtu.be/I_ViWYo7-10
the only thing i found this :
but for a E350 .. not sur it's the same Torque specs
Quick Reply: Torques spces For Rear Axle
