Need help after oil change
So, +3 on reseat the o-ring. The only other issue would be if you badly over tightened the cap and cracked it.
Make sure all O-rings (3 I believe are replaced and the big one is seated correctly). I can see how sombody might not put the big O-ring its grove, but if if you look closely it's pretty obvious where it's supposed to go. The channel for it even has little cut out to get screw driver in there to take it out.
