E55 amg brake conversion - need part #'s
Old Apr 16, 2021 | 08:38 PM
Ian McFarland's Avatar
glk250
I know a few of you did the 8 piston conversion, do you have a list of part numbers that you used that one post is lacking the information in a complete list and another user posted a cl63 conversion in the same post kinda messing up clarity of the parts. If anyone can assist i would appreciate it.
THanks
Old Apr 19, 2021 | 10:24 AM
andreigbs's Avatar
GLK 250
You man want to ping @JohnnyC as I believe he had done extensive brake upgrades to his GLK and is a great source of information.
Old Apr 19, 2021 | 11:24 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
can i ask why? i have to do them on my e55 and would hate to pay for and do them on the glk that stops plenty fast as it is. the only reason i would upgrade to this is if you plan on using it on the track but i doubt that is why.
Old Jun 7, 2021 | 03:56 PM
Djorge's Avatar
GLK 220 CDI Sport
THanks
Hi I made it in my 2 GLKs (2nd one now. a 2-15 220 CDI) and nothing too special than direct bolt ons; the front calipers require 3-4mm spacers to adjust the calipers to std AMG 360x36mm rotors - I use Girodisc to minimize the huge unsprung weight this setup adds; the rears are also easy fitting w/ the correct rotors that will fit to the GLk drums too - pls search my past thred to find those details - I'm considering to add a C63 master cylinder brake booster to really enjoy the braking "feel"; important also the front hoses need to be "banjo" fitting type Brembo standard), so the original GLK front ones will be useless; the GLK rear hoses will fit to the Brembo 4 piston calipers; blow pic of ATE's rear specs if not mistaken for E & CLS class; https://mbworld.org/g/album/7946145
