Chargins & voltage problem
Old Aug 12, 2021 | 12:22 PM
sUkanaga255's Avatar
X204 GLK 3.0 m272.948 year 2010
Hi Guys,
couple days ago I had a problem with my MB (x204, 2010, 3.0 v6 petrol engine 272.948) - after listening a radio by 30 min without starting an engine - it was powerless and could not start. No troublecodes or dashboard's warning before.
I gone to workshop and they said that an alternator should be repaired (which they did - new Bosch regulator, new bearings, new main coil etc.) and also a battery should be changed due to less than nominal capacity (10 years old). Moreover, they said that there was the one troublecode - 0365, and they delete it - probably it showed because of the weak battery.
After that, by couple days, everything was perfect but today suddenly the red dashboard warning appeared (red battery symbol). When I turned off the car and turned it on again - it dissapeared and i drove through ca. 70 km without a problem - after that it showed again. So I switched off the car, then on - it dissapeared again.
I checked troublecodes by SD - the same 0365 was there - "the output for the actuation of the alternator has a malfunction".
The workshop claims that the alternator is 100% good - they checked it by a special tool.
ECU has been checked today - raported as not damaged.
I also checked the voltage when the engine is running - when it is running on neutral it shows ca. 12,6 v of loading. When I turn on a blower to the maximum speed - it shows ca. 14.4 v.
Now I have started to wonder if this voltage could be a normal situation and the reason of "intelligent charging system" connected with ECU which when the battery is full descends the charging to 12.6 and when the circuit is loaded by lights, blower etc. it increases voltage to 14 and more?
I made the short video - are your cars behave the same when starting and when the battery is fully loaded?
Old Aug 12, 2021 | 02:20 PM
Mmr1's Avatar
2013 glk 350
I’ll bet your only problem was the 10yr old battery, did you replace it?
Old Aug 12, 2021 | 03:16 PM
Yes I did - I have new Varta 80 / 800 battery
What is odd here - when I pull a plug from he alternator it normally loads the battery with above 14v
Old Aug 12, 2021 | 03:52 PM
Mmr1's Avatar
2013 glk 350
Cleaning all connections and grounds would be a good start.
Old Aug 12, 2021 | 04:09 PM
I did some and now I am waiting for electrician to check connections between ecu and alternator's plug - my last idea here in fact
