GLK 350 hard start
Old Aug 30, 2021 | 04:24 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
GLK 350 hard start
Hi All,
Bought a glk350 and it has a very slow crank. It always starts but very slowly. I replaced the battery and recently left the car sitting for 10 days. came back and it started like it normally does (slowly) but it started. I am guess since that is the case the battery is not loosing power. I am guessing the starter is getting old but dont want to swap it on a theory. Any other things i should be looking at?
Old Aug 30, 2021 | 08:16 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
First, have the battery tested for capacity. Then, verify you do not have a big voltage drop between the battery (+) and the starter or the battery (-) and the engine block. If that doesn't expose anything, you can do a draw test on the starter motor. If it's bad it'll draw excess current. If it doesn't draw a lot, and still cranks slowly, repeat the voltage drop tests.
Old Aug 30, 2021 | 08:41 PM
chassis's Avatar
2017 GLE350 4MATIC
When did you most recently replace the battery?
Old Aug 30, 2021 | 09:23 PM
Mmr1's Avatar
2013 glk 350
Yes you need the battery properly tested, If you have a volt meter testing voltage now and test it with someone cranking the motor, the amount of voltage drop will be a good idea of the issue. What brand , capacity and type of battery did you put in.
Old Aug 31, 2021 | 08:30 AM
insame1's Avatar
less than 6 months ago
Old Aug 31, 2021 | 09:00 AM
Mmr1's Avatar
2013 glk 350
I had a name brand battery go bad in one month . Most auto parts stores will give it a full test for free.
