Coolant temp dropping in cold weather?
#52
Drove to work today at -27.5C on the highway at 115km/hr. Engine would not warm up! Dang it…what else can it be? I’m sitting at only 60C for 30mins!
I tried lowering the cab temp to 16C, the engine temp went up slightly…to 65ish, but then my windows started to fog up.
#53
I’m reading on the forum that our water pump is controlled via a vacuum line? Is the pump normally on or off? I would assume that it fails on…which may explain my situation. But I have no leaks.
Would the remap have anything to do with the thermostat map? Since ours is controlled via a heating element.
#54
In the absence of any identifiable faults I can only speculate that the heater core might be oversized and is super-cooling the engine during extreme cold. But we've had the car from new and I don't remember this happening during previous winters. The only difference I can think of is that I did on OE tune with DEF delete over the summer. Wondering if the tune makes the engine run slightly cooler. A shot in the dark but Occams Razor sometimes works.
#55
I drove home at 120km/hr for 30mins. Temp did not go above 75C. Outside temp was -21C.
Im starting to think it’s the tune. It also idled slight rough when starting cold. At least the tune made it worst.
#56
'17 GLS450, '14 GLK250, Grandpa's Roadster
#57
Well, I suppose a way to confirm is to reflash the original map back into the ECU. But then I might get the adblue countdown again.
I will have to make some kind of front cover, and hopefully finish installing the webasto this weekend. This kind of extreme cold isn’t good on any car, the GLK is no exception. Just have to find a practical solution.
#58
#59
Spoke with Sam (ECU Program) on the phone today. He confirmed that the rough idle is normal in the cold, mine goes away after warms up. He offered to make a stock tune with adblue delete for me to try and see if the warm up issue goes away. I'm still very happy with these guys as they didn't deny anything, the feel I got from them is that they want to help - very rare these days. They weren't going to charge me anything extra to do this.
Today was -14C in the morning and -5C in the afternoon - both trip, the engine warmed up fully (very slow in the morning, but on my way home it was quick). I was talking to a co-worker who had his diesel truck tuned, he said that he noticed a significant difference in how the engine build temperature in the cold weather. His tuner found that it was because the map aims to lower exhaust back pressure - which builds heat. I wonder if the OE tune and my Economy tune uses the same strategy to gain power.
karmikan (01-10-2022)
#60
#61
#62
The engine taking longer to warm up than normal (even in really cold temps) can also be related to the EGR setting. If EGR is turned off, as most tunes do, then the engine exhaust is not being pumped back into the intake and it takes longer to warm up by only ingesting outside, fresh (cold) air.
#63
You beat me on that answer andreigbs. Stickman007 i think you mentionned earlier that your EGR is deleted? MY GLK is fully deleted except for the EGR and i have no problem reaching my operating temp. -25C today, driving 5km in the neighborhood to warm things up a little and it only takes 7km on the highway to reach op temp. In the diagram, #12 is what to look for.
#64
OE responded:
"Back pressure is always increased with higher boost targets from tuning. There is no change to back pressure at idle or cruise. I do not think this is related to temp."
Seems that we have a difference of opinion or a difference in approach between tuners.
#65
EGR would definitely contribute to warm up. I'm glad everyone is pitching in for ideas. I still do not regret changing my thermostat at 148k, but it seems to be the "go-to" answer for a lot of people.
It was 0C this morning and 5C in the afternoon - engine had no issues warming up even in slower speeds. In the city waiting at the lights, temp did not drop below 85C. I still need to find myself an Android device (I sold my soul to Apple) in order to load the OEM tune with adblue delete back on the car. Sam already emailed me that the tune is uploaded to the server and ready for me to flash - these guys are quick and professional! I will try to borrow an tablet or something this week...its suppose to get cold again next week so that'll be the real test.
#66
#68
Note - this is getting uncomfortably close to the limits of my technical knowledge but I think that this is a pretty close description..
Cold air is denser than warm air and cooler air is desirable in a combustion engine because it results in greater expansion of the air/fuel mixture during combustion hence more power. This is the purpose of post-turbo intercoolers. A problem arises from this process because high temp combustion generates high NOx emissions. My understanding is that the EGR warms the intake air in a controlled way using exhaust gases in order to keep the combustion chamber temps below the NOx threshold (whatever that is). This balancing act between cooled air input and EGR warming is controlled and depends on throttle input and various temp and pressure sensors.
dzl_benz (01-13-2022)
#69
I'm remembering more...
My Duramax had an EGR cooler. The cooling was accomplished by exposing the exhaust gas to the coolant, which would warm the coolant. So, cutting out the EGR would eliminate the coolant heating effect from the EGR cooler.
#70
Basically, EGR is used to reduce the formation of NOx emissions, which are created when the combustion chamber temperature exceeds 2,370 degrees. Pumping exhaust (EGR) back into the engine helps to cool the combustion chamber because EGR has almost no oxygen in it. Without oxygen, the temperature stays below the NOx-producing threshold, and the emissions coming out the tailpipe are cleaner.
#71
2015 GLK 250 BlueTec with AMG Sport package.
No, that's correct, it does lower combustion temps so less NOx emission produced. Coupled with SCR it removes almost all NOx from the exhaust on modern diesels.
#72
@stickman007 I'd test the pump with a vacuum pump to see if it holds the vacuum and check the surrounding area if there are any traces of coolant leaking. It's easy to do with only the engine cover removed, don't even need to remove air intake.
Is your car warming up quickly and holding temperature now when we have single digits outside ?
I had similar experiences during extreme cold here in Calgary with my CR diesel Golf and now with GLK Bluetec. The only way to get up to 90C without freezing up inside the cabin was to get the car to a highway for 20-30 min and have the front grill cover on! If I drove around the city roads, at the stoplight coolant temp would start falling down. My wife's gasser Golf warms up much quicker but I can still see temp needle starting to creep down at a particularly long stoplight! Modern diesel engines are too efficient to generate enough heat in ambient temps of -25C, -30C without some serious load. On top of that, all the emissions-related hardware has never been tested in these extreme temps either. So DEF heater/pumps fail, urea injectors freeze and fail, etc...
Here is the front cover for GLK that I have any time it dips below -20C... took a while to get it done but it works:
The following 2 users liked this post by dzl_benz:
owevers (02-04-2022),
stickman007 (01-13-2022)
#73
Is your grill cover custom made? Where did you find this? I would be interested in purchasing this.
To quickly heat up engine at the start-up, ECU controls the pump via vacuum line and disconnects it from the impeller via vacuum, so should be OFF. Once engine is hot it should be ON. I assume if the vacuum jacket fails (which is common on these engines) it should be always ON. This is from OM651 Intro brochure:
#74
Yeah, custom made. I couldn't find ANYTHING on the market ready for use on GLK at that time so had to make something up. The Sprinter grill cover that MB carries wouldn't fit GLK and it was really overpriced. I've used outdoor A/C cover but any other durable material would work. You can get the tarp eyelets kit from any other hardware store. The hardest part of this mini-project was to make a decent template out of paper/cardboard.
#75
Keep in mind that MB doesn't advise the use of winter grill covers, even though there are some available for Sprinters and such. If the temperatures are consistently well below freezing and you're not doing much (if any) highway driving to fully warm up the engine, then a cover helps things get warmer, faster.
BUT... if temps change from day to day or you guys do highway driving regularly, I would caution against a contrived cover that's a pain to put on and take off, which leads to it being left on all the time. That's asking for trouble, IMO.
YMMV
YMMV
